I have NEO netbook ,the problem is when i connect the ac charger i notice that the led of the charger is blinking so i open the machine and looking for the shorted parts and i found it.,a smd caps & a SOP-8 mosfet which is located near j-mbat1.,the model is NIKOS PD1503YVS,.i can't find a datasheet for this IC so please help me.is there any compatible replacement for this IC?
Nikos mosfet
Re: Nikos mosfet
Does the mosfet not have any writing on it at all? The cap can be replaced with similar size. It's not perfect, but for the most part ceramic SMD caps are designated by their size. Take a junk laptop apart and you'll find one you need off of it. -
Re: Nikos mosfet
Hi did you find this;http://products.niko-sem.com/index.p...od_list&cat=19
Please can you update your profile with Country and Mains VoltagePlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Nikos mosfet
Perhaps one of these would work? FDS6982AS
Any laptop gurus watching?Attached FilesPlease upload pictures using attachment function when ask for help on the repair
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by Mike_HoDear All
Anybody have experience to repair L13 Gen2 Board Number : LAR-2 PD charger problem?
I have one board the U4201 CSD87501L are burned and the 20V_VBUS_USB2 can't switch to 20V_VINT_IN, after replace this Mosfet it's still very HOT and just use few hours will burned again. i have repeat replace this Mosfet 3 times and all dead.
After that i try to shorted Mosfet Source 1 to Source 2 to bypass the 20V, and found the Control Gate 1 and Gate 2 voltage both are 20v same with 20V_VBUS_USB2.🤨
So did anybody know this case will need to replace... -
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
- Loading...
