HP G62 won't power on. Burnt IC - Can't identify.
  • docksteaderluke
    • Jul 2011
    • 39
    Hey guys,
    I have an HP G62-358CA laptop that won't power on. When the power button is pressed the machine powers up then shuts off (within half a second). I've opened up the case and found a burnt IC near the RTC battery (PQ67). I can't read the label due to damage and therefore can't find the part number.
    None of HP service manuals go into "schematic-level" detail so I haven't been able to figure out this ICs function nor where to find a replacement for it.
    Is anyone familiar with this part of the circuit that can lend a hand in identifying this part?
    Thanks!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: HP G62 won't power on. Burnt IC - Can't identify.
    Try this schematic: http://lqv77.com/download/697/ It doesn't match 100% (there's no PQ67) but i'm sure you'll find what you need if you take a close look, as the main blocks seem to be the same. What i can tell you about that part is that it's a power mosfet in SO-8 package, but the rest is up to you to find out.
    A working TV? How boring!
    • mockingbird
      • Dec 2008
      • 5484
      I wonder if this is what happens when cheap chinese AC adapters are used.
      • docksteaderluke
        • Jul 2011
        • 39
        Thanks Th3_uN1Qu3. I found the part. If only the burnt IC hadn't fused to the system board then I'd be able to replace it!
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Use a heat gun and you should be able to remove it.
            I would cut the legs off the IC.
            • docksteaderluke
              • Jul 2011
              • 39
              I had already tried the heat gun (I have a reflow station). The IC basically fell apart. The board seems to have been damaged too as a couple of the legs wouldn't come off and lifted the top layer of the PCB. Luckily, the three pins on the IC where the PCB started lifting are all connected internally and there is another connection point nearby. It might end up being a bit of a hack, but it may just work. Here's to hoping!
              • jetadm123
                • 2169
                You also might want to check some of the surrounding components to see if they shorted to ground, which in turn could have caused that nasty failure.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  That would make it the source then. Don't be fooled by that - the pins aren't connected together for convenience, but because the device must switch fairly large currents. My advice would be to find out where that trace is going and use a nice heavy stranded wire to bridge it to the new mosfet, soldering to all 3 pins of the source.
                  • docksteaderluke
                    • Jul 2011
                    • 39
                    Nice. That was my plan.
                    In the datasheet you provided the AO4712 is used in conjunction with an AO4496. On my board I've found an AO4712 used in conjunction with a NIKOS P2003BVG (in the power circuit, whereas the one that fried was down by the CMOS battery). Upon looking at both datasheets the specs of the two chips are similar but still a bit different. How sensitive are these circuits. Will it matter if the power/current ratings are off by a bit?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      The Nikos device is weaker. Now to answer your question: Small differences don't really matter, it'll start up with almost anything if that mosfet was the only problem, but do have a temperature probe handy to check if your replacement runs at a reasonable temperature.
                      • incore
                        • Oct 2014
                        • 3
                        • aceh
                        hi how do you solve this problem, if this is done, I have the same problem, hard to find ic NIKOS P2003BVG
                        • Ramee
                          • Jul 2014
                          • 218
                          • Israel
                          If you like Chinese product, you can get it from here
                          http://www.aliexpress.com/item/10pcs...047271808.html
                          • incore
                            • Oct 2014
                            • 3
                            • aceh
                            ok thank u
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5071
                              • New Zealand
                              They are on eBay also: http://www.ebay.com/itm/5PCS-P2003BV...-/371080454742
                              Probably more reputable seller too (been around longer, anyway!)
                              -David VanHorn
                              • swimllamaswim
                                Precision 5550 LA-J191P No Power, Burnt ISL9538
                                by swimllamaswim
                                I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                                Here are the voltages measured at that chip:
                                To note, DCIN at Pin 17 is low,...
                                09-21-2025, 12:26 PM
                                09-06-2024, 05:59 AM
                              • Gentian
                                Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                                by Gentian
                                I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                                09-27-2025, 11:03 PM
                                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 02:15 PM
                                HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                09-07-2024, 05:20 AM
