will laptop work without battery charge controller?
  • fabiog
    • Jul 2011
    • 102
    Have an Acer Extensa 5630 that had liquid spilled on keyboard and fried the battery controller BQ24745.
    Now only the battery power led blinks when the power button is pressed so now I'm wondering If i remove the battery controller will the computer switch on but unable to charge the battery or does it really need this chip?
    Thanks for any help.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: will laptop work without battery charge controller?
    A lot more than the battery controller could be fried by a liquid spill... it *should* still work from AC without the '24745 but you will have to permanently fix some signal outputs (like power ok).
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • Klevjetack
      Charge a L19D3PDA battery externally from the laptop
      by Klevjetack
      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
      03-05-2024, 07:26 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • dclass-pro
      Latitude 3301 not charge battery
      by dclass-pro
      Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
      I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
      I noticed 2 things:
      1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
      2) if I try to turn it on without the battery...
      05-06-2025, 06:19 AM
