Toshiba C655-S5060 Low USB Voltage
  • KSMike
    • Jan 2012
    • 5
    I realize what bad form it is to ask for help in one's first post. However, I'm not asking. I'm begging for help. :-) Also, this is truly much more of an electronics question than a computer support question, but I'll first describe what I've done in order to help rule some things out.
    I have two identical laptop PC's (Toshiba C655-S5060, but I don't think that matters - and actually I have three of them but to keep this simple I'll just use two). They were bought at the same time, are used the same way with nearly identical applications, and have been used about the same amount. They're almost exactly one year old with original batteries. They are low-cost laptops (possibly a clue) but have been solid overall so far. They belong to my twin teenage sons.
    Just before Christmas, one of them began having a problem with his iPod repeatedly connecting and disconnecting, in rapid-fire fashion, so he couldn't get it to sync. Initially I assumed it was just the latest in a series of iPods my family has owned that died for no apparent reason, but began troubleshooting anyway. I plugged the "bad" iPod into the other kid's laptop, and it connected just fine, and stayed that way. Hmm, maybe it's not the iPod after all...
    So back on the now-suspect laptop, I did all the usual things - uninstalled/reinstalled iTunes (probably 5 times by now), reinstalled chipset drivers, turned power management off for all the USB hubs/ports, reset the iPod itself (probably 20 times by now), checked BIOS configuration & version - nothing seemed to make any difference. I scanned for viruses/adware using both MS Security Essentials and Malwarebytes with current signatures - nothing found by either one. Still, every USB device I try on this laptop other than the iPod works just fine.
    Digging around even more on the 'Net, I found a post from someone who had concluded that these 3rd generation iPod Nanos were particularly sensitive to voltage, and would disconnect much more easily than most devices if the slightest variation in voltage occurred at the USB port. So... I thought, "there's an angle I hadn't considered, maybe his laptop battery is just getting tired."
    So I did a bit of side by side testing, with the two laptops set up next to each other, cold booted, each plugged in to their respective AC adapters (which both test fine on output voltage BTW). I made up a USB breakout cable so I could monitor the voltage at the ports. (These laptops have two USB ports, physically adjacent, and both directly on the motherboard. As far as I can tell, whatever voltage is present on one port, is the same on the other port, at least when no load is present.)
    On both laptops, the USB voltage is around 5.15VDC when running on the AC adapters, and around 5.10VDC when running without the adapters. When I plug the problematic iPod into the laptop which has no problem, the USB
    voltage stays about the same; it might drop a few 100's of a volt but no more than that. And the numbers stay the same whether running on the AC adapter or not.
    But - when I plug the iPod into the suspect laptop, the USB voltage immediately starts dropping. After about 30 seconds, the voltage is down in the 4.5 - 4.8VDC range. After several test cycles, it appears the iPod disconnects at about 4.7VDC.
    I tried swapping the batteries between the two laptops, cold booted them both, and repeated the test. The voltage drop stays with the suspect laptop, it does not follow the battery.
    One of my next theories was that there was a faulty solder connection somewhere on the motherboard, since the delay before the disconnect seemed like it might be a thermal or vibration issue. I pulled the MB out and inspected all the joints under magnification and bright light. I found nothing obvious.
    Yesterday I found an Intel white paper ( if you're interested, especially page 5), which has a nice simple explanation of good USB circuit design and a description of some of the more common USB circuit failures they've seen. They make a big point about the capacitor(s) near the USB ports: "A common problem seen here is the use of inexpensive and low quality bypass bulk storage capacitors that have a high ESR or not enough rated capacitance. In accordance to the USB Specification Revision 2.0, the VBUS power lines must be bypassed with no less than 120μF capacitance of low-ESR capacitance per USB port." These Toshibas have a single aluminum electrolytic near the ports, but I didn't note the ratings on it. I wish I'd found this article before I took the MB out (and then put it all back together), since now I'm questioning what is more suspect - a VR, or that cap near the ports. Remember, this is a laptop that Toshiba designed to a price point, and it's a low one.
    As a workaround, I did connect a powered USB hub to the problem laptop, and was then able to connect the iPod, do a complete restore and re-sync of a large music library, with no problem. That served the purpose of proving that the voltage issue is the problem, and my son appreciates having his tunes back . Priorities, you know. But an external hub kind of defeats the purpose of a laptop. With it being barely a year old (a couple of weeks out of warranty and Toshiba refused to do anything to help), I'd like to try to fix it. A schematic would sure make me feel better, but that's not likely to happen it seems.
    I'm pretty good at soldering and am well equipped to do it. I have the lighting, magnification, etc. But am not sure which direction to go at this point. I wish I would have at least checked the ESR on that cap while I had the MB out.
    I'm really sorry for such a long first post, but thought it would be better than having anyone spend time writing a response for something that's already been tried. If anyone has any thoughts or advice, I'd greatly appreciate hearing them!
    Mike
    Olathe, KS
    Mike
    Olathe, KS
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Low voltage on USB ports
    Your model is too new to have the schematics leaked, but you can search around for older Toshiba schematics and look at how USB power is supplied; that circuitry doesn't change much.
    A bad filtering cap will cause excessive ripple, but otherwise not change the voltage like how you're describing; the open-circuit voltage is fine, but you're unable to draw much power from the port. The USB specification allows for up to 500mA; you can test this by using a 3W 10 ohm resistor (it will get rather warm, since it will be dissipating 2.5W of heat.)
    The first schematic I came across was for a Satellite A100; it doesn't have fuses (which I thought may be the problem) but USB power comes from system +5V and goes through G545 MOSFET switches. If yours uses similar circuitry, those may be defective and become high-resistance. You will need to trace the circuit on your model with a moderate load (~50 ohms, 100mA/0.5W or 20% load) applied to find out where the voltage drops off. I guess system 5V should be OK because you didn't say the laptop behaves erratically.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Not too sure about that one.
      Found this, for a Satellite C655D. (c) 2010 and it uses an Athlon II dualcore or a Sempron with a relatively new chipset (AMD RS880M) and DDR3 RAM
      The other one is for a Satellite C650 and C655, using a Core 2 Duo, Pentium Dualcore or a Celeron with an Intel GM45/GL40 chipset and either DDR2 or DDR3 RAM (depends on chipset/sub-model I guess)
      Dunno which one of the two it is. The first one sounds about right from the age. The other one is using considerably older parts
      • KSMike
        • Jan 2012
        • 5
        The 2nd one is it! The D model is an AMD variation, the non-D is Intel (I believe). The 3 of them I bought are definitely all non-D, Intel,T4400 processors.
        I'm not sure how far this will go - it would be nice if they'd included components list with specific part numbers & values, but this might give me the possibility of making some progress. Thank you!
        Mike
        Olathe, KS
        • b700029
          Banned
          • Sep 2010
          • 640
          That's the service manual, not the schematic.
          Tells you how to take it apart and such, but not too useful for component-level troubleshooting.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Toshiba C655-S5060 Low USB Voltage
            Moved to laptop troubleshooting. also made the title reflect the subject better (to increase chances of being seen by a knowledgeable expert).
            sigpic
            (Insert witty quote here)
            • inflex
              • Aug 2012
              • 544
              Oh dear, I thought I had found my beloved wanted schematic, alas, it has 404'd on me
              Anyone end up with a copy of this?
              YouTube Repair Videos - https://www.youtube.com/user/19PLD73
              FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
              • JeffJ
                • Apr 2012
                • 189
                I found it here.
                I am trying to diagnose why i only get 5V to the battery charge circuit and the rest of the board and no power/charge light.
                • YvD-Electronics
                  Request BIOS files to flash Toshiba C55-A-1TX laptop
                  by YvD-Electronics
                  I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                  Why I am pretty sure I need this to repair?
                  1) Power supplies seem OK.
                  2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                  3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                  4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                  08-09-2024, 10:05 PM
                  Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                  09-06-2024, 09:30 PM
                  Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 08:47 AM
                • RdeveLabs
                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                  by RdeveLabs
                  To all the members here...
                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                  05-05-2025, 04:59 AM
                  Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 06:11 AM
