What's the consensus here on copper shims?
  • thesloc
    Banned
    • Dec 2011
    • 587
    Basically a copper shim is supposed to prevent the laptop from over-heating and frying your GPU (or CPU)
    But I keep getting different answers, some say this heatsink traps more heat than it should, others, that it prevents overheating all-together.
    I have never installed one myself and I've worked on hundreds of laptops by now, usually, a dab of artic silver and a well-seated heatsink does the job for most overheating purposes.
  • yyonline
    • Jul 2009
    • 692
    Re: What's the consensus here on copper shims?
    I haven't installed one either. In my mind, if it needs a copper shim, there's some serious issues with the cooling design and it's only delaying the inevitable. I keep a good amount of different thicknesses of thermal pads on hand for replacing them in laptops. Thermal paste won't work in these scenarios, as there's too big of a gap to bridge with thermal paste. As long as you use the correct thickness of pad and keep it under pressure, they do a decent job of transferring heat.
    My personal laptop is Dell Latitude D620 with the failure-prone Nvidia chip. (Zero issues to date...knock on wood.) This seems to be a common choice for adding copper shims for the Nvidia chip. However, I figure it probably won't do much. The Nvidia chip and CPU share a heat pipe and heat sink. The fan doesn't kick in until either the CPU or GPU reaches about 75C. Once it does kick it, it cools the GPU and CPU down to the high 40s in less than a minute. So, the thermal pad is transferring the heat just fine. With the factory fan programming, I'm not sure copper will be much help. If anything, it could be the opposite, delaying the fan from coming on and allowing the chip to stay hotter for longer.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      If it didn't come with one then you don't need one.
      Mann-Made Global Warming.
      - Dr Seuss
      • severach
        • Aug 2007
        • 1055
        All the HP laptops in the class action said that. You're essentially saying that if the heat design is substandard then toss it out. I quite agree but I can't get others to let loose of their laptops.
        sig files are for morons
        • Ven
          Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
          by Ven
          Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
          Issue Description:
          1. CPU Overheating to 100°C
            • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
            • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
            • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
            • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
            • Thermal
          02-12-2025, 03:57 PM
        • rictechie
          copper pad in board peel off
          by rictechie
          Hi I'm newbie when it comes to electronics repair. My copper pad where my diode sticks has peeled off what is the most efficient way to make the copper pad stick to the board? epoxy? ink mask? I want to hear your suggestions
          07-20-2024, 11:49 PM
        • Nagyesz
          Dell inspiron 13 5000 - Doesn't turn on, overheating
          by Nagyesz
          I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
          Should I inject voltage somewhere, or should I replace the ICs right away?
          So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
          07-13-2024, 11:27 AM
        • technicalspecialist
          Vintage fan repair, copper wire question
          by technicalspecialist
          I currently have a customer's vintage fan on the work bench to repair.
          It uses an induction motor with 4 poles. One of the poles is open.
          I couldn't find the break so i cut off the original wire.
          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
          The enamelled copper...
          03-16-2023, 12:54 PM
        • Tomylee
          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
          by Tomylee
          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
          Here's what I've observed:
          All ribbon cables are properly connected
          Battery is present and in good condition
          No reaction even with screens disconnected
          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
          06-26-2025, 02:33 PM
