Has Anyone Tried Freezing Their Dead Li-Ion Batteries?
  • Paul678
    • Nov 2011
    • 402
    My pack is 10.8 Volts, which is 9 cells, but the measured
    voltage was way below the 9 x 0.6V=5.4Volt limit for a
    still-good battery.
    So I'm throwing it in the freezer for 12 hours:
    http://www.wikihow.com/Revive-a-Dead-Laptop-Battery
    We'll see if a miracle happens..... haha
  • mockingbird
    • Dec 2008
    • 5485
    Re: Has Anyone Tried Freezing Their Dead Li-Ion Batteries?
    It's gimmick, doesn't really fix anything.
    There is a way to improve old cells by giving them some voltage. I don't remember exactly how it is done.
    "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
    -Leonid Brezhnev (On the Yom Kippur War)
    • golemmaster
      • Jul 2009
      • 100
      I used to revive laptop batteries by zapping them on a car battery. Doesn't always work because some have some kind of protection built into them.
      • Clydeuk
        • Jan 2012
        • 193
        I tried this freezer idea, initially the battery (according to windows) would only charge up to 63%, ran for 2 minutes before hibernating the system (sudden drop to 3%). With all power saving features switched off the laptop ran on the battery for over an hour. The amber charge light never went green though, and one night after charging the battery decided to just give up, charging only to 3% and lasting a very short while.
        Here's the odd thing, after I did the old freezer routine (which has never worked by the way!) the laptop does all kinds of odd things. Firstly the amber charge light turns to green after 10 seconds or so of being connected. Secondly, the laptop starts up very slowly, the mouse pointer freezes and the keyboard will not work. The battery will also not run the laptop at all now. Removing it everything works as it should.
        I think the smart monitoring thingy inside the battery pack has failed in this case, never seen one confuse the computer this way, but you live and learn
        • G3n1us
          • Jan 2012
          • 14
          • Estonia
          With -20 to -30 degrees celcius outside, dead batteries have been pouring into my shop for replacements. This is proof enough for me, that freezing them will do no good.
          What you can try though, is disassembling the pack, disconnecting the cells one-by-one and charging them individually. Make sure you use proper voltage and current and don't overcharge them. If the cell gets too hot to touch comfortably, stop what you're doing. You don't want lithium burning on your desk. Check youtube to see what it looks like.
          • Koda
            • Aug 2011
            • 317
            • Macedonia
            I've seen some improvement when moderately heating batteries but that won't last very long, as for freezing G3n1us is right, that will completely destroy the battery.
            Guns don't solve problems. I'll take 12
            • carrzkiss
              Cyberpower cps1500avr not charging batteries
              by carrzkiss
              Hello, all.
              Cyberpower Battery Backup Unit.
              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
              Checking the voltage, it was down to 22v.
              I quickly removed everything...
              06-15-2024, 02:10 PM
            • howardc64
              Where do repair shops buy MB replacement batteries?
              by howardc64
              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
              07-25-2024, 10:42 AM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • davidebaldini
              UPS ruins batteries every three months
              by davidebaldini
              Problem description:
              My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
              UPS model:
              The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
              10-02-2019, 06:19 AM
