Dell D505 -I know what a STICKY is - is this a DUSTY
  • selldoor
    Slow Learner
    • 7870
    Bought this for spares - broken screen- I have to wonder if it was working before the screen broke.!! havent stopped laughing long enough to get it
    stripped and rebuilt.
  • lti
    • May 2011
    • 2557
    Re: Dell D505 -I know what a STICKY is - is this a DUSTY
    Maybe the original owner got mad at it for overheating and punched the screen.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
