dv6000 wont charge or power on
  • xboxhaxorz
    • Jan 2011
    • 196
    So i have the laptop apart, i put the ac/usb board on a preheater and used hot air to flow the solder. I then put fresh solder on the connectors underneath the actual ac port. The light will come on when plugged in, however it wont turn on. It will turn on with the battery that has been charged externally.
    This is the part that needs to be replaced and its cheap.
    http://cgi.ebay.com/HP-DV6000-65W-DC...5#ht_502wt_932
    However, i want to verify that it is the cause before ordering it.
    I dont understand electronics as well as you all, but i have all the tools. How would i go about using my multimeter to test and make sure this is the cause?
    If the laptop turns on with the battery connected then would the mobo be fine? Or is it possible that part of the mobo is bad, the part being where it gets the ac power?
    The power board has 2 cables, i assume a cable is for usb and the other is for the actual power.
    Also the charger is not at fault, its a charger from another dv6000
  • mattbrad2
    • Jan 2011
    • 122
    Re: dv6000 wont charge or power on
    Just so I understand you correctly - the "light" you mention when plugged in; is this the blue light ring around the DC jack or the charge light on the front panel of the notebook?
    If its not actually charging the battery, I would check the mosfets around the motherboard where the DC jack cable is located and also around where the battery is plugged in. They will show shorted in both directions when checked with a DMM. The other possibility is the Maxim power controller. It controls the actual act of charging the battery however you usually wouldn't get any standby voltage from it either so the laptop wouldn't turn on with an externally charged battery but I've seen stranger things.
    • xboxhaxorz
      • Jan 2011
      • 196
      Yes it is on the ac jack. The power cord when plugged in does not charge OR turn on the laptop. The laptop turns on only with the battery. I will check the mosfets, but they are not on the mobo itself they are on the daughter board.
      • mattbrad2
        • Jan 2011
        • 122
        You are going to need to check the mosfets on the motherboard, not on that daughter board. The only electronics on that board are for the USB connector. Follow the positive (yellow or red) wire from the motherboard connector and it should lead first to a P-channel mosfet (AO4407 probably). This is a common problem in these laptops. If it tests fine, you may have a problem with the power controller.
        • xboxhaxorz
          • Jan 2011
          • 196
          http://img.photobucket.com/albums/v3...z/DSCN0210.jpg
          This is a pic of the board, the ac plugs into that and then the 2 plugs go into the mobo. I took a look around the 2 plugs and did not locate a mosfet, i could have missed it though.
          http://img.photobucket.com/albums/v3...z/DSCN0209.jpg
          • xboxhaxorz
            • Jan 2011
            • 196
            alright i found this article from you pointing out the mosfet thanks
            but my problem is different, the unit WORKS on battery power but not on ac power
            AO4407 is responsible for for working off of battery power. since it does work of battery power but not ac, i dont think its that mosfet.
            is this correct?
            • mattbrad2
              • Jan 2011
              • 122
              is this correct?
              That is correct. More than likely it is a faulty power controller. I don't have a spare DV6k board around me right now but I believe these use Maxim 8734 controller. You'll see a small square IC near the battery contacts. These are a bear to replace. You can replace it with some flux and a lot of patience. Check digikey for a replacement. They should be about $6-7 for one.
              • kiranfocuz
                • Jun 2011
                • 12
                here is no problem with Motherbord mosfets , only issue with Nvidia chipset . try to heat 150 digree heat for 1 minut . and wait 2 or 3 minut . try to On your laptop display will come . this Solution for maximum HP DV nvidia chipset serios
                • skywalker
                  • Jul 2010
                  • 33
                  I dont see how this would work . unleaded solder reflow at 217+c
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    And lead-free reflows at even higher temp. 150C is the equivalent of hitting it with a hair drier. Sure, it'll work.... for a few days.
                    Anyway, this is an electronic not an electrical issue. A reflow won't do anything.
                    A working TV? How boring!
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • ipatch
                      troubleshooting microsoft surface pro 4 no power no led charge light
                      by ipatch
                      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                      10-05-2023, 11:59 AM
                    • proxneo
                      iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
                      by proxneo
                      Dear reader
                      TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
                      I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
                      12-01-2023, 04:14 AM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
