Dead Laptop after attempting to replace Inverter Board
  • ykilde
    • Nov 2010
    • 17
    My laptop's backlight was not turning on, so I attempted to replace the inverter. While checking the voltage and testing the fuse on the old board, one of the leads from my MM slipped and touched the fuse and pin#1 on the connector leading to the mother board.
    Now after replacing the inverter, the laptop does not turn on at all. The only thing I get is the charge light when I plug in the AC adapter.
    I went as far as opening the laptop and checking the F1 fuse along with several other fuses and resistors but they all checked out fine.
    Anyone have any pointers? BTW, this is a HP DV1000.
    Thank you in advance.
  • Pyr0Beast
    • Feb 2009
    • 406
    Re: Dead Laptop after attempting to replace Inverter Board
    Is Pin#1 Ground?
    Perhaps a blown mosfet on the vrm circuit.
    • jetadm123
      • 2169
      If you could post a few photos of where you had the "accident", then maybe members can point out specfic devices for to check.
      • ykilde
        • Nov 2010
        • 17
        Thank you all for the quick replies. Pin#1 is 18V
        With the battery in, I am getting ~18V at that point and also both ends of the fuse. This is the old board and I replaced it with a spare fuse I had for testing purposes with the same amperage but it's a fast acting fuse instead of the OEM slow blow.
        Inverter Board:
        Where I touched with the DMM:
        Motherboard (red circle is where the inverter board/LCD panel plugs into):
        • Pyr0Beast
          • Feb 2009
          • 406
          This is weird. If you shorted 19V to ground there shouldn't be anything wrong. That is direct feed from power supply.
          Unplug the screen completely and try to turn it on.
          • ykilde
            • Nov 2010
            • 17
            I unplugged the connector at the motherboard and it does not turn on. One thing I know for sure is if the inverter board is unplugged or not grounded, it will not boot up.
            Thanks for your help.
            • Pyr0Beast
              • Feb 2009
              • 406
              Hm ? No boot from inverter or no turn on ?
              • TECHMECH
                • 21
                Try checking for a shorted mosfet near the LVDS Connector. Check that you have all standby voltages as well.
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  Try checking inverter ground then. It may also be burned.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    our shop boss plugged a used inverter into his uncles laptop (dv6000), laptop sparked and died
                    then a few months later he plugged a used keyboard into this ladies laptop, same thing
                    oddly enough i'm posting this from my dv1000. and no you can't have my motherboard :P
                    • ykilde
                      • Nov 2010
                      • 17
                      No Boot from either the old or new inverter boards.
                      Do I need to remove the MOSFETs to check for shorts? Some of the MOSFETs are too small to work with my soldering iron. I know, I should be using a hot air workstation. Also, are you talking about the motherboard or inverter board?
                      Inverter ground is good. Before I shorted the two points, I forgot to install the screw (ground) and the laptop would not turn on.
                      Thanks for all your help!
                      • k370
                        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                        by k370
                        I have a NM-A321 board that is dead, with no power at all.
                        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                        • +3VALW
                        • +5VAUX
                        • 1.2VSUS_PWRGD
                        • 3VALW_PGD
                        • 1.05VAUX_PWRGD
                        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                        09-23-2024, 11:57 AM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • corrize
                        Nikon D5 – dead, power board issue ?
                        by corrize
                        Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                        When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                        I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                        Now, I try to understand how it works.
                        There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                        04-03-2023, 09:13 AM
                      • Asraf Atb
                        by Asraf Atb
                        01-27-2025, 05:02 PM
                      • lostone
                        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                        by lostone
                        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                        05-19-2024, 11:40 AM
