Macbook Pro A1708 no boot/charging
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello everyone, I have a MBP A1708 with the following problem: Not turning on, only the fan starts to spin for a few seconds then nothing. No chime, nothing. CPU gets warm, All voltages are present on the board as far as I measured.
    If I do SMC reset, it does the fan spin procedure, but otherwise it's doesnt reacts to the power button.
    Two things I managed to pin point:
    Battery voltage is 2.2V, very dead wont charge even If I leave it on the charger.
    And after following this wiki (https://repair.wiki/w/A1708_2016,_20...ar_MacBook_Pro) I found out that injecting 0.9V on L2950 only draws around 40mah, where based o nthe wiki the IC U2800 should draw around 68mah. Is it possible that I should replace U2800 or there can be something else I should check/try first?
    Thank you!
  • No Lan
    [Macbook pro A1708] [Boot loop] [Trackpad ?]
    by No Lan
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
    05-24-2025, 03:09 PM
  • dbuergi
    Macbook A1708 with water damage and problems after removing U2800
    by dbuergi
    i got a A1708 with water damage. I cleaned everything and the board started normal. But the next day i got 20v but no booting. Thermal cam showed over 160c (never had a chip getting this burning hot before) in U2800 and some shorts on the caps around it. After removal shortages were gone and i installed a donor U2800 which worked before.
    Sadly now the device stays at 5v, 0,4a and 1,9w and i don't find the problem.USB ports worked fine before....
    03-17-2025, 06:27 AM
  • twonk9098
    Macbook Pro mid 2015 battery required to boot?
    by twonk9098
    I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
    The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
    This model has the newer trackpad which is not clickable when turned off.
    At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
    If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
    12-10-2024, 06:51 PM
  • veedo
    Macbook A2442 820-02098 boot and display issue
    by veedo
    Hi All
    I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
    Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
    I found component UD290 ( SF0101-I2C) little...
    04-01-2024, 06:06 AM
  • PITERPENY
    Macbook A2251 no boot
    by PITERPENY
    The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
    01-05-2025, 03:11 PM
