I've got this macbook air 2017 A1466 which initially was working good exept for the wifi adapter not being detected by the OS.
After inspecting the board, I discovered some traces of liquid damage around the area of R3558, R3559, R3554 and the pin 1,2,3,4 of U3540 slightly dull.
I cleaned the area with alcohol, took some measurements on the resistors and in the process i accidentally knocked off R3554.
Also the test pads in those area and other resistor were a bit corroded.
By cleaning the corrosion, some of the board mask went off exposing the ground layer on the side next to R3559 R3554.
I soldered a new resistor of 200K in the place of R3554. I had to scratch some mask off cause the pad number 1 was gone.
I made sure that none of the pin number 1 of R3554 and pin number 2 of R3559 were getting in touch with the exposed ground layer. Measuring the resistance to ground of PP3V3_WLAN line showed more that 300K stable.
Upon reconnecting the magsafe board with the ribbon cable to the main board (connector J9500), I flipped that ribbon cable upside down by accident.
After attaching the magsafe, I came up with no led, no power no fan spin.
PPBUS_G3H line is 0V without shorts.
PP3V42_G3H line is 0V without shorts.
PPDCIN_G3H line is 0V without shorts.
PPDCIN_G3H_ISOL line is 0V without shorts.
CHGR_DCIN line is 0V without shorts.
The only voltage I've found is 7V on PPDCIN_G3H_CHGR line
Could be that I've blown up Q7180?
Any help will be well appreciated
