820-00165-A No Power
  • speggio91
    • Apr 2020
    • 83
    • Italy
    I've got this macbook air 2017 A1466 which initially was working good exept for the wifi adapter not being detected by the OS.
    After inspecting the board, I discovered some traces of liquid damage around the area of R3558, R3559, R3554 and the pin 1,2,3,4 of U3540 slightly dull.
    I cleaned the area with alcohol, took some measurements on the resistors and in the process i accidentally knocked off R3554.
    Also the test pads in those area and other resistor were a bit corroded.
    By cleaning the corrosion, some of the board mask went off exposing the ground layer on the side next to R3559 R3554.
    I soldered a new resistor of 200K in the place of R3554. I had to scratch some mask off cause the pad number 1 was gone.
    I made sure that none of the pin number 1 of R3554 and pin number 2 of R3559 were getting in touch with the exposed ground layer. Measuring the resistance to ground of PP3V3_WLAN line showed more that 300K stable.
    Upon reconnecting the magsafe board with the ribbon cable to the main board (connector J9500), I flipped that ribbon cable upside down by accident.
    After attaching the magsafe, I came up with no led, no power no fan spin.
    PPBUS_G3H line is 0V without shorts.
    PP3V42_G3H line is 0V without shorts.
    PPDCIN_G3H line is 0V without shorts.
    PPDCIN_G3H_ISOL line is 0V without shorts.
    CHGR_DCIN line is 0V without shorts.
    The only voltage I've found is 7V on PPDCIN_G3H_CHGR line
    Could be that I've blown up Q7180?
    Any help will be well appreciated
  • reformatt
    • Feb 2020
    • 1440
    Re: 820-00165-A No Power
    Pretty sure I've done that once or twice with the ribbon cable, it shouldn't create any issues.
    Tests should be done without battery installed. If you are using a genuine Magsafe charger, the load provided by R7012 should trigger the charger to enable the full voltage. Sometimes I've seen leakage through D7005 or Q7180 from the battery interfere with the Magsafe turning on.
    You can test for this by installing battery only (no magsafe) and check for voltage at R7012. If you have anything above 0 here, then you have leakage back from the battery.
    • speggio91
      • Apr 2020
      • 83
      • Italy
      Hello reformatt, thanks for the hint.
      All the previous tests was made with just the magsafe connected, without the battery.
      I have 2 geniuine magsafe 2 charger and the results was the same.
      I tried to connect just the battery and measuring on R7012 I got 0.090 mV.
      Is that still considered an important Leak?
      I noticed that with just the battery connected, now I see these voltages:
      PPBUS_G3H = 7.6V
      PP3V42_G3H = 3.4V
      PPVRTC_G3H = 3.4V
      PP5V_S5 = 0V no shorts to ground detected
      PP3V3_S5 = 0V no shorts to ground detected
      • mon2
        • 14499
        D7005 is a suspect.
        With only the battery, measure the voltage to ground of each pin on D7005.
        With only the official power adapter, perform the same voltage checks.
        Post each measurement. If the MagSafe led is off then this important 3v42 power rail is not functional.
        • speggio91
          • Apr 2020
          • 83
          • Italy
          Hello Mon, thanks for your message.
          D7005 on battery only:
          pin 1: 7,6V
          pin 2: 51mv
          pin 3: 7.4V
          D7005 on charger only:
          pin 1: 2V
          pin 2: 44mv
          pin 3: 1.5V
          Some observations:
          when i measured D7005 with the charger connected, those voltage were decreasing very fast on pin 1 and 2. Even after I unplugged the charger, those voltages were still there and eventually reached 0V after few minutes.
          If i connected and disconnected the battery, and taking measurements right away on the diode, pin 1 is 1.7V and pin 2 1.5V both decreasing fast. So i guess the charger doesn't have any effect on those values and maybe the diode is faulty.
          • speggio91
            • Apr 2020
            • 83
            • Italy
            I have an update:
            I'm feeling misarable to say it but the culprit was the J7000 not being connected to the magsafe board
            Not having experience on these boards before I didn't think of connecting it, I thought that J9500 flat was enoug haha
            Now the macbook is powering on and loading the system. The wifi adapter is also being recognized. Everything seems to work well exept for one thing.
            Maybe it's me, but I think now the system is running a bit slower than before, the apps are taking lot of time to load, even the system preferences took 10 seconds to show up. If I move the windows, the movement is smooth though.
            I've connected every flat cables, sensors, camera, etc.
            The model has 8GB of ram and an i5, 1.7Ghz Cpu.
            • mon2
              • 14499
              Test after a pram reset.
              • speggio91
                • Apr 2020
                • 83
                • Italy
                final update:
                the general slow down of the OS got fixed apparently by plugging in the battery. The first tests after reassembling the machine was done without it.
                I also did a PRAM reset and it did increase a bit more the loading speed.
                Thank you all for the interest and support, you are a guarantee!
                • iMuhtaseb
                  A1502 2015 820-4924 no power
                  by iMuhtaseb
                  board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
                  I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
                  I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
                  I've taken some measurements:
                  PPBUS 12.6
                  PP5V_S5 present
                  PP3v3_S5 present
                  S4 rails when...
                  06-29-2024, 05:29 AM
                • flusher
                  A2485 MBP16 M1 820-02100 not charging
                  by flusher
                  Bought myself a project. Waterdamage to the left wing. Front side got damage on top up to SSD area. Back - near CD3218 both CD3217. Had to replace a lot of caps and resistors to make it perfect. No shorts. Didnt lift any chips yet but microscope shows good balls from sides. Anyway. It powers up and boots fine.
                  Right single usbc shows 20v on meter 0 amp
                  Left upper usbc shows 5v 0 amp
                  Left bottom usbc shows 20v 0 amp
                  magsafe shows orange but also does not charge
                  nothing produces beep from mac when on
                  when off - single usbc and magsafe produce beep but no beep...
                  08-27-2025, 08:25 PM
                • cubytus
                  Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                  by cubytus
                  Hi to all,
                  I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                  I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                  Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                  01-10-2024, 01:26 AM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  08-19-2025, 06:11 PM
                • TrueSword88
                  Kogan - KALED65XU9220STB - Blue Vertical Line
                  by TrueSword88
                  Hi all.
                  I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                  The line just happens to coincide with the end of COF and start of the next COF (attached).
                  The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                  Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                  Hoping to fix...
                  05-05-2023, 04:28 PM
