Iat50 la-3491p rev 1.0 no power
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hp 520
    s/n: Cnd80843rl
    iat50 la-3491p rev 1.0
    issue: Led shows up for a second then off
    bq24703 charger ic
    pins - name voltages
    1 - batdep - 3.2v
    2 - srset - 0v
    3 - acset - 0v
    4 - vref - 0v
    5 - enable - 0v
    6 - batset - 0v
    7 - comp - 0v
    8 - acn - 19.0v
    9 - acp - 19.0v
    10 - nc1 - 0v
    11 - nc2 - 0v
    12 - batp - 0.2v
    13 - ibat - 0.4v
    14 - nc3 - 0v
    15 - srn - 0v
    16 - srp - 0v
    17 - gnd - 0v
    18 - vs - 0v
    19 - alarm - 0v
    20 - vhsp - 17.7v
    21 - pmw# - 19.0v
    22 - vcc - 19.0v
    23 - nc4 - 0v
    24 - batdrv - 0v
    25 - acdrv# - 19.0v
    26 - acdet - 0v
    27 - acpres - 0v
    28 - acsel - 0v
    [MOD EDIT]
    Link to schematic and boardview - https://www.badcaps.net/forum/showthread.php?t=44188
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
  • mon2
    • Dec 2019
    • 14724
    Re: Iat50 la-3491p rev 1.0 no power
    Review the voltage to ground of each pin of PU2A. Post each measurement. ACDET is 0V which it should not be with the adapter connected.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      PU2A
      1 - 3.2V
      2 - 1.2,
      3- 1.3V,
      4- 0V,
      5- 0V,
      6- 0V,
      7- 0V
      8- 19.0V
      acdet - pin 26 - 0v
      RESISTANCE TO GND - none
      i ahve the boardview but ive tried all software i cant open it
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        Originally posted by kalilinux25
        PU2A
        1 - 3.2V
        2 - 1.2,
        3- 1.3V,
        4- 0V,
        5- 0V,
        6- 0V,
        7- 0V
        8- 19.0V
        acdet - pin 26 - 0v
        OK ive made it work ive use the lower bversion of allegro 15.7 top open this so I found the pq10
        PQ10
        PIN1 -0V
        PIN2 -3.2V
        PIN3 -0V
        • ktmmotocross
          Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
          by ktmmotocross
          Acer 515-54G
          DA0ZAWMB8G0
          Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
          i dont uderstand this. Charger ic BQ24780S
          ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
          What is pulling my ACDET down when i apply power even without BQ ic...
          12-02-2022, 12:03 PM
        • opethfan
          GH5JJ TLA-K701 no charging no power no acdet
          by opethfan
          hi
          i'm not skilled with laptop repair, i need some helps:
          i don't have ACDET on PU1802 and in consequence i don't have ACDRV
          please check pictures...
          04-04-2025, 08:17 AM
        • ronaldopdias
          Acer Aspire 3 A314. Not Charging.
          by ronaldopdias
          Laptop Model: Acer Aspire 3 A314
          Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
          Charging IC: BQ24780 which I have repalced.
          Issue Description:
          I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
          1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
          2. ACOK is not present (0V): Is missing as well.
          3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
          What I Have...
          12-19-2024, 04:15 AM
        • kwyjibo
          Help understanding ACDET voltage divider A315-23
          by kwyjibo
          Greetings.
          Aspire A315-23 board (da0z8emb8c0 Rev c), no power.
          19VDC is at PQ3 pin 5. Nothing coming out, and started working around the power circuit.
          The ADP_ID pin (3) was pushed all the way inside the DJ jack (new one on order), causing it to not make contact with the barrel connector on the AC Adapter (nothing new), and where it wasn't my laptop I didn't just want to jump it to the DC Jack ground and call it a day.
          I can see the voltage divider circuit from PR71 and PR69 to PQ9. But some reason I cannot remember how if the DC...
          01-24-2023, 11:02 PM
        • myth77
          acer predator g9-593 no ACDET
          by myth77
          i am playing with this laptop for a few days..when i got it the motherboard was really damaged with someone "trying" to repair it...couple of pads missing, bridges in soldering chips and on mosfets and so on...I replaced two dead mosfets, one capacitor, ite chip, charge manage ic, 3 and 5 volt regulator and maybe even something more i cant remember
          when i put charger in laptop i have 19v but ACG is not rising so mosfets are not opening. So i checked charge manage ic and i am missing ACDET=0 V.
          There is no boardview for this board only for g9-591 but this one is...
          05-29-2020, 04:49 AM
