MacBook Pro13 A1706 only no CPU Rail
  • SVAudio
    • Oct 2023
    • Deutschland
    I received a MacBook Pro 13 inch from a friend for repair
    Model: A1706 820-00239
    The device shows no reaction to the power button,
    no water damage, no optical problems, nothing noticeable.
    It was closed working and since then it has been dead.
    I have already checked the following:
    1) With battery connected:
    Charging via USB-C on all 4 ports OK Voltage PPDCIN_G3H goes to 20V, PPBUS_G3H to 13.1V.
    2)Further measurements without battery and other components except USBC power supply
    PPDCIN_G3H 20,0 V
    PPBUS_G3H 13,1 V
    PPBUS_HS_CPU 13,1 V
    PPBUS_HS_OTHSV 13,1 V
    PPBUS_S4_HS_TPAD 13,1 V
    PP3V3_G3H 3,3 V
    PP3V3_G3H_SMC_ISNS 3,3 V
    PPVCC_S0_CPU 0,0 V (7 Ohm to GND)
    PPVCCSA_S0_CPU 1,0 V
    PPVCCGT_S0_CPU 0,0 V (2,7 Ohm to GND)
    PPVCCIO_S0_CPU 0,95 V
    PPVCCEDRAM_S0_REG_F 1,05 V
    PPVCCEDRAM_S0_CPU 0V (55 Ohm to GND)
    PPVCCPRIMCORE_SUS_PCH 1,0V
    PP0V6_S0_DDRVTT 0,6 V
    PP0V6_S3_MEM_VREFDQ_A 0,6 V
    PP0V6_S3_MEM_VREFCA_A 0,6 V
    PP0V6_S3_MEM_VREFDQ_B 0,6 V
    PP1V8_SUS 1,8 V
    PP1V8_S4 1,8 V
    PP1V8_S3 1,8 V
    PP1V8_S3_MEM 1,8 V
    PP1V8_S0 1,8 V
    P1V0_SUS 1,0 V
    PP1V0_SUSSW 1,0 V
    PP1V0_SUSSW 1,0 V
    PP1V0_S0SW 1,0 V
    PP5V_S5 5,0 V
    PP5V_S4 5,0 V
    PP5V_S0 5,0 V
    PP3V3_S5 3,3 V
    PP3V3_SUS 3,3 V
    PP3V3_S4 3,3 V
    PP3V3_S4_BT 3,3 V
    PP3V3_S4_TPAD 3,3 V
    PP3V3_S5_SSD 3,3 V
    PP3V3_2V7_NAND_VCC 2,7V
    PP3V3_S4_SOC_PMU 3,3V
    ALL_SYS_PWRGD: 3,3 V -> OK
    I then took a closer look at the CPU power supply:
    PP5V_S0_VCORE1 5V
    PP5V_S0_VCORE2 5V
    PP5V_S0_VCCSA 5V
    PP5V_S0_VGT1 to 3 all 5V
    PPVIN_S0_CPUVR_VIN 13,1V
    PP5V_COREVR_VCC 5V
    CPUVR_PGOOD 0V
    Does anyone have a tip for me where I should look further?
    The clocks 32k and 24MHz... are also there
    Unfortunately it's my first attempt at MAC repairs, I usually do more digital audio devices
    I am therefore grateful for every help
    Greetings from Germany Stefan
  • reformatt
    • Feb 2020
    • 1399
    Re: MacBook Pro13 A1706 only no CPU Rail
    What about PPVCCSA_S0_CPU? Check closely around the sides of U7100 for contamination or corrosion too. Depends on where it lands....sometimes you get lucky and it just kills the drive. Other times, you end up with shorted MOSFET's and a dead CPU.
    Corrosion on MAC's is quite often small and easy to miss, so look carefully under a microscope. It can be something as small as a dead insect whose decaying corpse shorts out a cap etc.
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • Danielreinaa
      HELP need password bios Macbook A1706
      by Danielreinaa
      Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
      Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
      Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
      gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
      Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
      09-07-2024, 03:47 PM
    • capon5153
      Macbook A1706 works perfectly but no data on USB C
      by capon5153
      hello,
      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
      06-22-2025, 09:42 AM
    • B2L_Repairs
      Macbook A1706 touchpad and keyboard not working. Please help
      by B2L_Repairs
      Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
      10-09-2023, 04:56 AM
    • obelix24
      A1706 - Macbook pro - one USB-C port only 20V 0A
      by obelix24
      I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
      I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
      There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
      There were some broken pads under CD3215 but i've recreated them.
      What should be...
      05-22-2024, 08:04 AM
