Mac EFI Toolkit
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    #81
    this is the reading without a chip
    • MuertoGB
      • Sep 2021
      • 94
      • United Kingdom
      #82
      PITERPENY I'm not sure, I've no experience with the EZP. You'll have to find a "compatible" 1.8V chip model by chance in the list. I had to do this when I had a TL866II+.
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        #83
        I can't help but share my small success! After a long sorting through all the chips, I did not get a result even after I figured out which chip! The chip manufacturer is Macronix (MXIC) and the chip is MX25U3235F Click image for larger version
Name:	MXIC 2024-11-25 195314.png
ID:	3514951 ! You should not press test in the program, this will not give anything and there will be an error, you just need to read it right away and then we will get the ROM file Click image for larger version
Name:	2024-11-25 201717.png
ID:	3514952 ! By the way, if you do not use the 1.8v adapter, nothing happens to the chip, but the file will not be complete (no serial number, etc.) Click image for larger version
Name:	2024-11-25 201646.png
ID:	3514953 ! But nothing burns, this is good! Of course there is much more information on EFI ROM Click image for larger version
Name:	2024-11-25 202136.png
ID:	3514954 but the fact that you can quickly rewrite the serial number is priceless! And once again I want to thank muerto for the work done! thank you
        • MuertoGB
          • Sep 2021
          • 94
          • United Kingdom
          #84
          PITERPENY Thanks for sharing, I see the hardware config MD6M was missing from the internal database so it has been added for the next update. HWC: MD6M = CC: MacBook Pro (16-inch, 2019).
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            #85
            I didn't rejoice for long. Apple uses 2 types of chips for SoCROM. And I thought they were the same chips, but the programmer only reads one type that doesn't have the chip name: Click image for larger version
ID:	3515049 , and for some Click image for larger version
ID:	3515051 reason doesn't read the one that has the marking.
            • MuertoGB
              • Sep 2021
              • 94
              • United Kingdom
              #86
              PITERPENY One is a 25 series SPIROM, one is a 24 series EEPROM (SEPROM). Never touch the SEPROM
              • MuertoGB
                • Sep 2021
                • 94
                • United Kingdom
                #87
                Version 2.0.2 released:
                https://github.com/MuertoGB/MacEfiTo...leases/tag/202
                • reformatt
                  • Feb 2020
                  • 1411
                  Working on a dump of a 2017 iMAC (820-00579 board) with a locked BIOS. It's the current version from Ventura (529.140.2.0) and showing that APFS driver not present. Just a cosmetic thing so not a biggie.
                  Also noted there is no Save As option. If you make a change (e.g. clear NVRAM) and don't save it, there is no option to Save, other than to go back in again and do the same action then hit save.
                  • MuertoGB
                    • Sep 2021
                    • 94
                    • United Kingdom
                    #89
                    Is there any chance you can zero the serial number in that firmware and send it to me? I might have broken something in the update, as there were changes made to the GetIsApfsCapable function.
                    As for the 'save as', I've purposefully designed it that way. When you apply a patch it will load in a clone of the binary buffer, patch and promt the user to save it. If one cancels, it will discard all patches in memory.
                    Click image for larger version  Name:	image.png Views:	0 Size:	36.9 KB ID:	3526825
                    • MuertoGB
                      • Sep 2021
                      • 94
                      • United Kingdom
                      #90
                      Version 2.0.3 released:
                      https://github.com/MuertoGB/MacEfiTo...leases/tag/203
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        #91
                        I wonder if this is the socrom chip on the m1? Is it the same as on the t2?
                        • Bravetech
                          • Jul 2023
                          • 5
                          • Nigeria
                          #92
                          Thanks so much
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            #93
                            MUERTO version 202 saw the firmware SocRom A2337 M1 Click image for larger version
Name:	Знімок екрана 2024-12-29 224541.png
ID:	3537657 but version 203 did not Click image for larger version
Name:	Знімок екрана 2024-12-29 225333.png
                            • Ly8888
                              • Jan 2025
                              • 中国
                              #94
                              [QUOTE=Kien Pham;n3509543]
                              please guide me to unlock icloud from t2 rom chip. i am stuck at this step. model mac mini 2018 A1993 I have the bin file of the chip
                              I would be grateful for your help
                              HI Kien Pham ​,
                              u T2 icloud is unlock??
                              • MuertoGB
                                • Sep 2021
                                • 94
                                • United Kingdom
                                #95
                                Hi, nothing changed for the T2 SocROM code from v202 > v203 (https://github.com/MuertoGB/MacEfiTo...6603d44f38a65d). M1 devices are not supported, only Intel based T2 SoCROM.
                                If you like, you could pass me the firmware so I can test, however it would still not load after. There's nothing of interest in Apple Silicon ROM apart from iBoot version.
                                Originally posted by PITERPENY
                                MUERTO version 202 saw the firmware SocRom A2337 M1 Click image for larger version  Name:	Знімок екрана 2024-12-29 224541.png Views:	23 Size:	23.6 KB ID:	3537657 but version 203 did not Click image for larger version  Name:	Знімок екрана 2024-12-29 225333.png Views:	25 Size:	2.0 KB ID:	3537655
                                • PITERPENY
                                  • Jul 2023
                                  • 455
                                  • Ukraine
                                  #96
                                  https://fex.net/s/pfbffef
                                  socrom2337
                                  • PITERPENY
                                    • Jul 2023
                                    • 455
                                    • Ukraine
                                    #97
                                    I apologize, I made a mistake, not 202 but 200 version
                                    • Arshad alam4659
                                      • Aug 2020
                                      • 156
                                      • India
                                      #98
                                      I have a1706 (820-00923-a) IN THIS BOARD SMC IS SHORT I HAVE A NEW SMC BUT HOW TO PROGRAM THIS SMC I HAVE YOUR SMC TOOL BUT THIS MODEL IS NOT LISTED CAN U PLEASE ADD THIS MODEL OR ANY OPTION TO WRITE IN BLANK CHIP
                                      • Arshad alam4659
                                        • Aug 2020
                                        • 156
                                        • India
                                        #99
                                        A1990 2019 MODEL WITH MDM LOCK THIS TOOL CAN PERMANENTLY REMOVE MDM
                                        • MuertoGB
                                          • Sep 2021
                                          • 94
                                          • United Kingdom
                                          #100
                                          This is a thread about Mac EFI Toolkit, The Tiva E SMC is not supported. Turn your bloody caps off, the whole forum can hear you.
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • sezsizada
                                            hp 15-fb0000nx bios editing request
                                            by sezsizada
                                            Hello
                                            I need your advice and help on a topic.
                                            Since we did not have the existing chip on the HP motherboard with a faulty VGA chip, we installed a different chip. How can we enable this on the device?
                                            old vga chip GN20-P1-A1
                                            new vga chip GN20-P0-A1
                                            I add original bios water
                                            thank you in advance...
                                            07-21-2025, 10:24 AM
                                            Copy DMI info easily with Hex editing software and Macro script
                                            by SMDFlea
                                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                            02-28-2023, 02:14 PM
                                          • Aditya11ttt
                                            On Board Ram Disable via Bios Editing
                                            by Aditya11ttt
                                            Post Hp | Dell | Asus | Lenovo
                                            on board Ram Bios we try to disable via bios edit.
                                            07-31-2022, 08:03 AM
                                          • Rustam14
                                            help with bios editing UX325E
                                            by Rustam14
                                            Zenbook 13 UX325 Intel Core i5-1135G7 UX325/425EA REV 2.1
                                            Hello! I can’t edit the bios on the asus, I tried to manually glue it from ASUS support and through Fit.
                                            turns on without iso tries to initialize and turns off...
                                            04-16-2022, 05:16 AM
