Alienware 18, Nvidia GTX 880m presumably shorted
  • GTAVC16
    • Aug 2023
    • 9
    • Switzerland
    Hi guys!
    I'm in need of some support so I can try to fix my laptop/gpu.
    While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
    I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
    No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
    I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
    However, I know that I should not willy nilly try to stick my multimeter at everything in my card to measure resistance. :-P
    In my opinion one should only take a measurement if one knows what kind of result is expected.
    What am I working on?
    I have an almost ancient gaming laptop, It is an Alienware 18 R1 built around 2013-ish.
    There is some confusion about their naming conventions, it is not a m18 and also not a M18x. Those are different gaming laptops and most of the guides I found were about those. :-/
    CPU: Intel 4930MX i7 (not 100% sure about that)
    GPU: 2x Nvidia GTX 880m with SLI
    Motherboard: VAS10 LA-9332P
    Power Supply: Original AC/DC adapter, output rating: 19,5V, 16,9A
    What happened?
    While gaming, the laptop suddenly shut down and refused to start again.
    The current weather is quite hot, so I presumed that it shut down due to overheating.
    This never happened before and I always take measures to insure propper airflow for the fans. (Laptop on a hard table, steering exhaust away from intake.)
    After leeting it cool cown a bit, it still refused to start.
    This is when I found out that the green LED from the power supply brick has shut down, indicating no power due to some sort of protection mechanism.
    Unplugging the PSU from both the laptop and the wall, and plugging it back in to the wall socket, the green LED lights up again.
    However, it shuts down again as soon as I plug it back to the laptop.
    There is a click at the laptop and a slight smell ozone, indicating some sort of arcing.
    My diagnostic procedure
    I looked up a disassembly video on youtube and disassembled my laptop to check for my first presumption about the issue, a damaged charging port.
    This is/was a high-end gaming laptop and could be a common issue.
    However, I could not find any kind of damage around the charging area, no burn marks, no loose parts, nothing.
    When plugging in the board to the PSU, the light stays on, indicating that the issue is currently not present.
    Getting in deeper in my rabbit hole, I found that the primary graphics card tends to fail often, so I unplugged the PSU and mounted the primary Nvidia 880m back on. Now, when connecting the PSU, it shuts off again.
    To be sure that it is related to this GPU, I did the same with the CPU and secondary GPU and the power stays on.
    The primary GPU seems to be the issue, but what now?
    I've taken a good look at the GPU and did not find any damage or burn marks.
    I'd like to take some measurements, but I only have experience with measuring electrics, not electronics, so I need some kind of visual guide for where to measure and what values to expect.
    I was unable to find any schematics for the GTX 880m.
    Some help would be greatly appreciated.
    I have a multimeter on hand, and I'll put pictures of the GPU in the attachments.
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Alienware 18, Nvidia GTX 880m presumably shorted
    The GPU is quite old and the death was just a question of time. Most likely a dead Core where you actually can't do anything.
    However, I'm not sure whether you're in the right section here at all since we're more talking about a socketed GPU than a Laptop motherboard.
    However, you have a second, working GPU so you could at least compare resistance measurements from the various inductors to start with and also take voltage measurements by any chance?
    But clarify first: Does the laptop not start at all with the suspected faulty GPU, which would lead to a failed High-Side or is it"just" shutting down after a few seconds?
    FairRepair on YouTube
    • GTAVC16
      • Aug 2023
      • 9
      • Switzerland
      Thank you for your answer, Sephir0th!
      It doesn't start at all when the faulty GPU is connected, both with and without connected battery.
      No beeping, no lights, no booting, the same lifesigns like a DMV employee.
      The PSU trips as soon as I plug it into the board with the faulty (primary) GPU connected.
      The PSU does not trip if both CPU and secondary GPU are connected.
      When I push the power button, nothing happens. I tried both short and long presses.
      What pins would I need to compare to get further along with what is wrong with the card? Forgive me my lack of knowledge on that part.
      Even if the card is unsalvagable, I'd still like to learn as much as I can.
      In addition, placing the primary GPU in the slot of the secondary GPU yields the same, the location of the problem seems to be this primary GPU.
      • Sephir0th
        • Oct 2020
        • 1282
        That's probably a high-side short. Don't test with power anymore. The main power rail of the mainboard is probably shorted with one of the power rails related to the primary GPU, as long as it is present on your board.
        So i don't know your skills... Are you able to identify the main power rail at the GPU and look for a internal shorted Mosfet. But pay attention, there are also Mosfets connected to GND and the resistance of the load is likely very low. So there might appear Mosfets as shorted, although they are not.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3590
          • slovakia
          mostly shorted some mosfet on main gpu rail. or shorted capacitor.
          measure resistance between two thick pads on mxm conector if u have resistance under 1ohm, u have short to ground/shorted lowside mosfet or capacitor/. if u have resistance 2-10ohm u have shorted one of high side mosfet
          • GTAVC16
            • Aug 2023
            • 9
            • Switzerland
            I just took some measurements and found 0.7 Ohm on the bottom side and 0.1 Ohm at the top side.
            How can I identify the power rail to find the damaged parts?
            • Sephir0th
              • Oct 2020
              • 1282
              That's the point: you need to find out what is PLUS and what is GND. Either from Injecting or from logical conclusions. Share a picture with your measurements included please.
              • GTAVC16
                • Aug 2023
                • 9
                • Switzerland
                I'm sorry if I'm being incredibly dense right now.
                Where exactly do I need to stick my multimeter?
                I've tried to figure this out since yesterday, but my lack of electronics experience shows. :-/
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  short on the 19 volt line.
                  this has removable cpu ?
                  if so remove gpu and cpu. check if 19volt still shorted (should be still shorted).
                  then inject 1 volt on 19volt like and check what get hot. probably a caps on the back of cpu or some mosfet or so...
                  had one alienware with dead caps and another one with dead mosfet.
                  not mainly it measns cpu and gpu are dead. expecially if u can remove them
                  put 1 volt on the big resistor close to power jack . it's very big so u can miss that one. before ofcourse with multimeter in diode mode check if it's shorted or not.
                  red probe on gnd (usb metal, other metal on mainboard) and black on that resistor (both side to be sure). then we procede further.
                  • GTAVC16
                    • Aug 2023
                    • 9
                    • Switzerland
                    Can you please take my screenshot and put some arrows on the points I have to take measurements?
                    This is literally my first time dabbling with electronics, i have absolutly no clue what components you mean with 19 line.
                    I'm sorry, but it isn't obvious to me, but I'd like to learn, how can I identify this 19 volt line?
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      measure are on the mainboard not vga.
                      also as i write: without cpu and gpu (if cpu is removable) psu green light still goes off ?
                      • GTAVC16
                        • Aug 2023
                        • 9
                        • Switzerland
                        The psu green light only shuts off if the primary GPU is installed.
                        The light stays on, if the CPU and secodary GPU is installed.
                        The light shuts off, if the primary GPU is installed in the secondary slot.
                        My conclusion is that my laptops primary GPU has a short somewhere, and thanks to the Sephir0th and ktmmotocross whom helped me tremendously, I took some basic measurements and found out that I have >1 Ohm at the power connectors of this GPU, indicating either a short to ground, damaged lowside MOSFET or a damaged capacitor.
                        Now my task is to find the damaged parts, but I have no idea where to measure.
                        I googled the parts number and found some MOSFET schematics, but the order of the pins somehow don't translate to the thing I have in front of me.
                        Also, what kind of measurement am I looking for? Measure everything to ground, across the MOSFET?
                        I really have no clue what is expected of me.
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          ive attached picture of one 880m i had in my old alienware. put multimeter in diode mode and red probe on rec spot. then one by one change the back probe to the 5 green spot and read value u have each spot. then measure also blue spot.
                          post results.
                          • GTAVC16
                            • Aug 2023
                            • 9
                            • Switzerland
                            Thanks for your help, dellxps15!
                            I've taken the measurements and everything comes up with 0.01V.
                            One of your pictures does not have any marking, is this on purpose or should I take some measurements from there, too?
                            • dellxps15
                              • Feb 2014
                              • 1588
                              • italy
                              edit checked on a vga i have here. blue spot is gnd, so it's normal to have 0,001.
                              do you have lab psu ?
                              • GTAVC16
                                • Aug 2023
                                • 9
                                • Switzerland
                                Sadly no, I might have one at work that I can use, but I doubt it.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3590
                                  • slovakia
                                  remove that 4 upper mosfets and check it
                                  • craig2991
                                    • Apr 2024
                                    • US
                                    Hello Sir, were you able to fix/turn on your lap top? I was having the same issue with my Alienware 18. Mine won't turn on and the AC adapter LED turns off when plugging into laptop. Reading the threads says the system must have a short. I don't think the ac jack cause the problem after carefully inspect the charging area. I suspet one of the graphic card is broken. I'm trying to dettach the both graphic cards to see if I can turn it on. Before I do that, just wanted to check with you to see if you have updates on this since we have similiar model and issue. Thank you!
                                    • reessi
                                      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                      by reessi
                                      Hello:
                                      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                      I started on the ACER:
                                      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                      10-29-2024, 11:31 AM
                                    • chestercc
                                      Alienware M18x Shorted CPU Mosfet
                                      by chestercc
                                      I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                                      I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                                      Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                                      07-16-2022, 06:05 AM
                                    • mgrharry
                                      Alienware Area 51M Monster Dual Jacks, 1 Shorted
                                      by mgrharry
                                      Alienware Area 51M laptop. This monster has an i9-9900K desktop CPU and replaceable GPU. For full performance it requires two power adapters. The system works, but complains of insufficient power when posting with only 240W adapter connected. Unfortunately there is a short to ground on one of the power rails so the secondary power adapter cannot be utilized. In testing there is a short across the pins of DC in connector so it seems like it should be an obvious short on a component like tvs diode that has blown to protect board. The shorted jack trace goes through board and on the other side there...
                                      07-22-2022, 09:07 AM
                                    • Yanleb
                                      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                      by Yanleb
                                      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                      D608, good
                                      D618 RF101L4S, good (See warning 1 below)
                                      D619 RF101L4S, good (See warning 1 below)
                                      D865 RF101L4S, shorted (See warning 1 below)
                                      IC464 Inverter HA MC74HC1G14, shorted...
                                      03-09-2020, 12:00 AM
                                    • modtool
                                      HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                      by modtool
                                      Hi to all,
                                      the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                      I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                      I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                      04-01-2025, 08:22 AM
