ipad air 4th doesnt working touch
  • khj
    • Jun 2023
    • 14
    • korea
    Hi guys.
    My ipad air 4th doesnt working touch.
    I replaced display but cant fix it. I think the reason is mainboard.
    I can hear some noise sound at this parts (i upload the picture)
    It is shield so i cant check now.
    What is the reason? Bad cap is the reason that touch is not working?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: ipad air 4th doesnt working touch
    Mostly filter or so is blown, you change digitizer?
    • khj
      • Jun 2023
      • 14
      • korea
      I changed lcd + touchscreen
      • mon2
        • Dec 2019
        • 14666
        What is the history of this iPad? Why was the display replaced?
        On at least one iPad model, the connection from the A10 CPU to the digitizer ic becomes disconnected at the BGA ball level. It is a well known pcba defect. The fix is to review the diode mode readings of the SPI bus connections used by the digitizer ic. The diode mode test will confirm if the SPI line is open or not between the CPU and the digitizer ic.
        Next, the A10 CPU has to be removed and reballed and then soldered back to fix this dry solder connection. Check some YouTube videos on this topic. We had a similar case with the ipad 7th gen. See the great video by Ayman in Egypt for the process details. We replaced the digitizer ic first and the touch did not return. Before this, we checked the diode mode readings of the digitizer ic.
        To date, we do not know if the A10 CPU used on the iphone is the same or not for the iPad. Lim in Malaysia has a video on the same fault and he briefly mentioned that if the A10 is replaced, then the serial number changes. No idea on how to fix this issue if the A10 CPU is replaced.
        Start with the simple check if loose inductors on the board. Post details on this iPad.
        • ApplePie14
          iPad 7 2019 10.2 Touch Not Working
          by ApplePie14
          My ipad touch does not work.
          I have tried restoring it with 3utools, but I get error codes -6 and 1110issue at “Updating NAND Firmware”.
          I tried DFU mode and iTunes, but the same thing happened.
          Is the only solution to replace the NAND?​
          04-24-2025, 08:17 AM
        • obelix24
          Macbook Air 2020 (a2179) - touch id not working
          by obelix24
          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
          02-09-2025, 12:57 PM
        • alpersen
          Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
          by alpersen
          On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
          10-24-2025, 01:55 AM
        • Gabriel Lucas
          microsoft surface pro 5 touch screen not working
          by Gabriel Lucas
          Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
          02-18-2025, 09:24 AM
        • ahmarzo
          MacBook Air a 1466 keyboard and touch not working
          by ahmarzo
          Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
          The voltage on connector j4800 is following
          Pin no 1-3.3v
          Pin no 10 3.3v
          Pin no 14 - 5v
          Pin no 15-20 all pins have 3.3v
          Have reballed the ic u 5000. And tried another ssd with working os .
          10-18-2025, 10:40 AM
