iPad 7 2019 10.2 Touch Not Working
  • ApplePie14
    • Dec 2024
    • 13
    • JAPAN
    My ipad touch does not work.
    I have tried restoring it with 3utools, but I get error codes -6 and 1110issue at “Updating NAND Firmware”.
    I tried DFU mode and iTunes, but the same thing happened.
    Is the only solution to replace the NAND?​
  • ApplePie14
    • Dec 2024
    • 13
    • JAPAN
    Checked the capacitors around the CPU and found some shorts.
    Will try to reball the CPU.​
    • mon2
      • 14169
      Cpu is powered by a low voltage rail. By design, low voltage rails will have a low resistance to ground. What are the resistance to ground measurements of these cpu capacitors?
      • ApplePie14
        • Dec 2024
        • 13
        • JAPAN
        I reballed the cpu and it fixed it.
        Thanks for replying.​
        • GeirAndersen
          iPad .pcb file collection
          by GeirAndersen
          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
          IPAD COLLECTION 1
          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
          12-09-2024, 09:28 AM
        • cheebster
          MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
          by cheebster
          Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
          Nand voltages are missing.
          I've found no shorts at all so far, no signs of heat via thermal camera either.
          PPBUS_G3H 12.31
          PP3V3_G3H_RTC 3.387v
          PP3V3_G3H 12.31v
          PP2v5_NAND_SSD0 0v 58 ohms
          PP2v5_NAND_SSD1 0v 57.8 ohms
          PP1v8_SLPS2R 1.8v
          PP1v1_SLPS2R 1.1v
          P3V3_G3H_SOCPMU 3.37v
          PP0V9_SLPDDR 0.9v...
          10-11-2023, 11:31 AM
        • Karmet
          MacBook Pro 16" 2019 NAND Swap
          by Karmet
          I couldn't find a post related to this, so if it exists please point me in that direction.
          I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
          I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
          07-24-2023, 10:48 AM
        • trepachka
          Converting HP EliteBook 840 G7 non-touch to touch if possible
          by trepachka
          I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
          The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
          I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
          04-27-2024, 11:15 PM
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
