Excruciatingly slow bios Dell E5570 LA-C641P
  • pingaroon
    • Nov 2019
    • 121
    Hi, a once-good board has suddenly developed a fault where it runs slow - I mean REALLY REALLY SLOW. With no peripherals attached (including no SSD/HDD), the bios screens can actually be seen redrawing/refreshing themselves and it takes 30 mins+ to boot an o/s off a USB stick. All the PS coil voltages are normal and everything on the board looks fine (and works fine). I have a couple of good working boards for comparison but can't find any difference between the 2.
    The problem is definitely not the bios.
    I've changed 2 of the crystals to no avail.
    What could it be?
  • aldopc
    • Jul 2017
    • 477
    • Chilito
    Re: Excruciatingly slow bios Dell E5570 LA-C641P
    What could it be?
    Hello, did I ever have a similar problem in the psid area, does the charger detect it in the bios in the battery status section, and shows the watts of the charger? or problem in the in.
    • pingaroon
      • Nov 2019
      • 121
      Hi, I'll check that tomorrow and report back, thanks. I did check the voltage on the ID pin earlier today and it is normal (3.3v).
      • reformatt
        • Feb 2020
        • 1495
        Abscence of PS-ID data from the charger will result in the CPU being throttled to the slowest speed and disable battery charging. 3V on this line doesn't prove anything; serial data is issued from a one wire chip in the charger to the EC and only appears as a short burst when power is first provided.
        • pingaroon
          • Nov 2019
          • 121
          Hi, 90W and 65W Dell chargers are both recognised normally in the bios (and both work normally on other boards), so it's not the charger.
          I've swapped out plenty of bad charger id diodes (PD6 in this case) in the past where the charger cannot be detected, but this board runs even slower than boards where the charger is not detected! Throttling on steroids!
          *headscratch*
          • mon2
            • Dec 2019
            • 14662
            To me, it is still the fault of the bios that is currently onboard.
            • pingaroon
              • Nov 2019
              • 121
              Hi - I used the same (me cleaned) bios in the other 2 (identical spec) good boards where it is flawless. I even tried with 2 or 3 other bioses from the tinternet but all with the same result: SLOW. Also, it was working perfectly with that bios and the fault suddenly appeared
              Bad EC, PCH? I have no idea...
              • mon2
                • Dec 2019
                • 14662
                Once you enter the bios -> have you tried to load safe defaults? Perhaps some incorrect setting that needs to be refreshed.
                • pingaroon
                  • Nov 2019
                  • 121
                  Yes, I've tried every possible combo, but no difference.
                  • pingaroon
                    • Nov 2019
                    • 121
                    Interestingly, the bios is saying the cpu is running normally at 2.40 GHz, but it's still so slow, so could the cpu be toast?
                    • mon2
                      • Dec 2019
                      • 14662
                      Disconnect anything and everything on this logic board that can be disconnected ie. ssd / drive / USB / etc. Then see if this boots normally.
                      Could a key on the keyboard be stuck? Causing the keyboard buffer to be flooded?
                      • pingaroon
                        • Nov 2019
                        • 121
                        There is nothing connected. Just the bare board and a USB keyboard, which is known good.
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • pirati
                          by pirati
                          Yesterday, 04:20 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
