Macbook Pro A1989 - 820-00850 A no boot
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    Hello All,
    I'm working on one Macbook Pro 13" A1989 board number 820-00850 A and i'm out of clue
    When i connect board with battery, keyboard, display, ... (everything) i'm getting 20V and current goes from 0.6A to 1.9A - it stays on 1.9A but nothing no chime, no apple logo, but i can click trackpad (as i know this means that T2 is ok)
    When i connect only board (everything disconnected) it's taking only 5V (on all usb-c) and 0.16A or 0.36A (it's just jumping to 2 values, doesn't stay on any)
    I've checked
    PPBUS_G3H - 12.3V
    PP3V3_G3H - 3.3V
    PP3V3_S5 - 0V
    I've connected to another mac and i was able to put it to DFU and start restore it finished with no error but not apple logo or chime.
    what i've done
    I've replaced UB400 but there is one ripped pad - NC_USBC_TB_RESET_L but i was not able to recreate it as there is no trace so probably NC pad. I've tried 3 UB400 chips and still the same issue (only 5V when battery is not connected)
    Any idea what should be checked next ?
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    Re: Macbook Pro A1989 - 820-00850 A no boot
    I've just checked when i connect power to each USB-C i get 1.1V only on XA and XB
    PP1V1_UPC_XA_LDO_BMC - 1.1V
    PP1V1_UPC_XB_LDO_BMC - 1.1V
    PP1V1_UPC_TA_LDO_BMC - 0V
    PP1V1_UPC_TB_LDO_BMC - 0V
    When i check in diode mode :
    PP1V1_UPC_TA_LDO_BMC - OL
    PP1V1_UPC_TB_LDO_BMC - 0.512
    • mon2
      • Dec 2019
      • 14995
      The LDO rail to power the BMC interface will only be active for the port used to power the logic board.
      Move the power adapter to the other USB-C port and confirm if the BMC LDO rail is then 1v1.
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        yes I know I've tested all test point for all 4 ports (I've also turned the cable on each port).
        does this mean that CD3215 needs to be changed and maybe it's faulty ?
        If yes can I use CD3215C00 (original on board was CD3215C00Z)
        • mon2
          • Dec 2019
          • 14995
          You are getting 20v so the ace controllers are working. If you are stuck at 5v then these power delivery controllers could be at fault.
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            yes i'm getting 20v but only when battery and other stuff is connected.
            if i connect only board itself to power it takes only 5v. So do you think i have to replace CD3215 ? can i use CD3215C00 or i have to use only CD3215C00Z
            • mon2
              • Dec 2019
              • 14995
              There are some models that require a working battery to boot even if using an external power adapter.
              Not sure if this is one of those models.
              On the ACE controller, check the website from Rossman. Often he posts the compatibility list. You should also ping suhms store on AliExpress to confirm. Then update this thread.
              On our many back end projects is a break out board to experiment with this ace controller. Started another one for the isl9240 but our building / my lab was destroyed by a drunk driver. Now each project is delayed.
              • mon2
                • Dec 2019
                • 14995
                This website lists them to be different:
                https://www.diyfixtool.com/products/...42357993177317
                • mon2
                  • Dec 2019
                  • 14995
                  Best to source the original and from reliable vendors:
                  https://www.masterliuonline.com/prod...riantsId=10139
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    What do you mean by ACE controller ?
                    • mon2
                      • Dec 2019
                      • 14995
                      Ace controller is the nickname of the cd321* devices from Texas Instruments.
                      • obelix24
                        • Jun 2023
                        • 300
                        • Slovakia
                        ok so I replaced both CD3215C00Z with CD3215C00, now the board is taking 5V and then switch to 20V.
                        I've tried to revive and also restore in DFU mode but I'm still ending just with padlock.
                        There is no error message in Apple Configurator 2 (I don't know where should I search for log from this app)
                        • mon2
                          • Dec 2019
                          • 14995
                          Nice!!
                          https://discussions.apple.com/thread/253277152
                          • obelix24
                            • Jun 2023
                            • 300
                            • Slovakia
                            this doesn't help as i have nothing on the screen where to put password.
                            Padlock is shown on the macbook where i started apple configurator.
                            • obelix24
                              • Jun 2023
                              • 300
                              • Slovakia
                              I've checked PP1V8_SSD and PP0V9_SSD both ok (1,8V and 0,9V)
                              Also I've checked
                              PPVDDCPU_AWAKE - 0,54V - I've checked on L7806 - according to schematics it should be 0,625V - 1,06V
                              PPVDDCPUSRAM_AWAKE - 0,8V
                              it looks like everything I'm checking is ok but not working. Enters DFU ok, restore with no error (it just stays long time in Installing system and then there is only padlock in Apple Configurator.) Anyone any idea ?
                              I was just randomly checking and on test point near T2 PP4V7_SE_TVDD I have only 2,49V but it should be 4,7V
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                I'm curious to reflash SOC ROM. But don't know if there is any ROM i can download to replace old one.
                                and also i have only EEPROM programmer something like this if it will work also ...
                                • apos
                                  • Apr 2022
                                  • 13
                                  • greece
                                  Hello,you may need U-BOS2 to flash bios .
                                  • obelix24
                                    • Jun 2023
                                    • 300
                                    • Slovakia
                                    is it not possible to do it some DIY way ? as don't need such expensive tool for 1 usage only
                                    • obelix24
                                      • Jun 2023
                                      • 300
                                      • Slovakia
                                      OK i was able to flash bios on original SOC ROM IC using my EEPROM programmer i have to be little bit creative and solder some small wires ... I've used AsProgrammer. I've tried 2 bios files that i've found online but i'm still getting error on line 500 or 600 ... but anyway i've tried to put the IC back and still exactly the same problem. I'm able to put macbook to DFU but when i try REVIVE or RESTORE i'm ending at Installing System (the bar goes under S (System) it's approx 50% and it stays there for few minutes and the i got only Padlock ...
                                      • pedribor
                                        • Apr 2021
                                        • 3
                                        • Spain
                                        hi obelix24
                                        I have the same problem. Could you solve it?​
                                        • MullySculder
                                          A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
                                          by MullySculder
                                          Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
                                          This was given to me by a friend who told me I could have it, if I fixed it.
                                          I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
                                          07-10-2024, 02:17 AM
                                        • Nikan.e
                                          MacBook A1989 repair / no CPU voltage no boot signs
                                          by Nikan.e
                                          Hello everyone.
                                          I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
                                          No CPU Voltage.
                                          U7800 Does produce voltages.
                                          T2 Chip warming up very very little.
                                          I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
                                          11-24-2023, 11:55 PM
                                        • No Lan
                                          [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                          by No Lan
                                          Hey everyone,
                                          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                          05-24-2025, 03:09 PM
                                        • twonk9098
                                          Macbook Pro mid 2015 battery required to boot?
                                          by twonk9098
                                          I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                          The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                          This model has the newer trackpad which is not clickable when turned off.
                                          At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                          If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                          12-10-2024, 06:51 PM
                                        • MyronViegas
                                          MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                                          by MyronViegas
                                          Hey guys,
                                          I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                                          Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                                          10-06-2025, 08:45 AM
