MacBook A1989 repair / no CPU voltage no boot signs
  • Nikan.e
    • Nov 2023
    • 20
    Hello everyone.
    I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
    No CPU Voltage.
    U7800 Does produce voltages.
    T2 Chip warming up very very little.
    I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode.
    I thought to myself that it might need a BridgeOS revive. Unfortunately, I am not in possession of another Mac, so I have used VMware to set up a Mac Sonoma system. Apple Configurator does see the device in DFU mode. But whenever I try to revive it, it starts but unfortunately does not complete.
    I am wondering, do you need to have a Mac, or does the revive option also work in a virtual machine? What about the touch ID/start button? Does the Macbook need to have one installed to be able to revive it (does the T2 chip check if that module is installed) or can it be ignored for now to revive the T2 chip?
    Any help or what I should check would be appreciated.
    Thanks in advance and best regards from Germany,
    Nikan
  • MyronViegas
    MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
    by MyronViegas
    Hey guys,
    I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
    Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
    10-06-2025, 08:45 AM
  • Madoy104
    Macbook Pro A1989 - No image, working fine with external monitor
    by Madoy104
    I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
    08-15-2024, 10:01 AM
  • bbqlovesribs
    A1989 Macbook No backlight but 12,6 v on f8400 but not boosting up
    by bbqlovesribs
    Hi everyone, sometime I opt to do thing by myself to learn how it works; Hi really enjoy the process, especially when someone else expert is teaching
    MacBook Pro
    A1989 4 thunder ports
    Board:820-00850
    Here I am for today,
    After changing thermal paste and some clean keyboard with 96% isopropyl, Mac reboots ok. Totally working.
    While doing reset smc just for a fresh restart, Macs turns off. After rebooting it, nothing changes.
    Took it to a repair man shop and find out that, if lcd is connected Mac doesn't start completely (20v, green...
    01-09-2026, 06:09 PM
  • it-mind
    macbook pro a1989
    by it-mind
    Hello guys i hope every one is ok i have a macbook labled a1989 that wont turn on i did some measurements and some checking in the videos i will attach any advice on what to do now...
    01-01-2026, 03:14 PM
  • BMCappelletti
    Macbook Pro 2018 A1989 - Only 5V - Had PPBUS_G3H, not anymore
    by BMCappelletti
    Hi everyone.
    Macbook Pro 2018 A1989, board 820-00850.
    Only 5V on the meter, and around 250 mAmps drawn. Lots of dust on the sides, as usual. Cap CD308. right over CD3215 (UB300) was shorted. I did have PPBUS_G3H at 12.3V. measured on CC851, if I am not mistaken.
    Replaced CB308 with a cap from another board, with same specs. Now I don't have a short on it anymore, but neither PPBUS_G3H.
    When connecting the meter to the USB-C ports it keeps restarting, except on front port on the other side. And CD3215 close to it (U3200) gets hotter than usual. F3000 is the fuse with 5V...
    12-05-2025, 03:18 PM
