a 2338 liquid damage 5v but works on battery
  • apos
    • Apr 2022
    • 12
    • greece
    Hello,i have a Macbook pro 13 A2338 with liquid damage.The fact is that works on battery ,but battery cannot be charged.
    There is an issue with USB ic UF 500 .I did change it but still not charging .
    I bought the S-UEM2 from SoFix to help me out and gives me an error to UF 500.I did change it again but still 5v and battery not charging ...
    Any help will be great.
    Thxxxx
  • mon2
    • Dec 2019
    • 14021
    Re: a 2338 liquid damage 5v but works on battery
    When you attach the power adapter to the logic board, what is the voltage and current draw showing on your USB-C power meter?
    The suggestion is to review the LDO power rails on each USB-C power controller (aka cd321* ACE controller).
    Each one must be working to power the logic board.
    • apos
      • Apr 2022
      • 12
      • greece
      Thanks mon2 for your fast replay ,i cannot find in open board where the cd321 is located.
      In the image below yellow has 5v red the one i have changed twice 0v.Also the charging port of UF 500 does not work .The other of UF400 gives 5v 0.40a.
      I am not a genius in electronics i have to mention.
      • apos
        • Apr 2022
        • 12
        • greece
        Hi again,I am checking the LDO power rails and i found that RF261 is missing on my board .Looks like board was made without it ,but in schematics exists.Try to put a new one and be back again .
        Thx
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • bykanovm
          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
          by bykanovm
          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
          Also, the laptop does not turn on without...
          04-02-2025, 02:45 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
          09-14-2023, 11:10 PM
        • Hondaman
          Cold temperature battery damage?
          by Hondaman
          A couple of evenings ago, my cell phone spent 6-8 hours on the floor of my car, which was parked on the driveway. Probably at or below 0 Celsius. When I took the phone inside, it was turned off, and the battery was at 0 percent (Galaxy S10 Plus). I charged it (wirelessly) without letting it warm up (yes, I know that was probably a mistake -- I probably should have put the phone onto an electric blanket I have).
          Now, when the battery reaches something like 72 percent or 75 percent, it charges normally. Below that point, it takes 90 minutes to add 10 percent to the phone's battery charge....
          01-05-2025, 05:22 AM
        • ferah831208
          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
          by ferah831208
          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
          03-18-2025, 01:18 AM
