Macbook A1502 820-3476
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello Namaste,
    This Macbook came in. It was heating up and not booting. There was light on the charger but no boot.
    Macbook was extremely dirty. Cleaned it a little and it started working fine. So we unscrewed the board and cleaned both sides of it.
    Post that it booted once and then i just got a fan spin and no boot. Got green/orange light on the charger as well.
    Did an SMC Reset and the machine switched on. We thought there may be crap under the SMC. So took the board out . As soon as i connected the charger a component burned out in I/O board. I replaced that component. Now the light is gone for good. Getting PP3v42 and PPBUS_G3H as normal.
    I tried using another I/O board and the same component got burned again.
    I am so stuck.
    PPBUS_G3H is at 12.6
    PP3v42 is at 3.4
    No light on the charger.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Macbook A1502 820-3476
    what component keep getting burned ? post picture. also when burned with io cable connected check if that component is shorted.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Originally posted by Instafixx
      Hello Namaste,
      I am so stuck.
      PP3v42 is at 3.4
      Update
      I reballed the SMC and the Machine boots up fine and works well. But there is no light on the charger and I am getting "Battery Not Charging " message when clicking on the battery icon.
      What can be the issue?
      • mon2
        • 14078
        Check the smbus lines on the battery connector. What is the voltage to ground of these pins?
        • Instafixx
          • Jul 2022
          • 374
          • India
          Hey,
          Thanks for the help. Turns out the component installed on the I/O board was faulty. Changed that and now its working fine. Thank you all for the help.
