Macbook A1502 SMC replaced. Can I use SMC A1466? Do I need SPI clean ME?
  • AlexVG
    • Apr 2022
    • 138
    • SPAIN
    Good evening.
    I replaced SMC on Macbook A1502.
    I have had SMC from A1466 only. It's the same but obviously has different program.
    Is it enough to clean SPI with
    https://www.badcaps.net/forum/troubl...-bios?t=100913
    and change SN?
    Thank you.
  • reformatt
    • Feb 2020
    • 1550
    SMC has is its own internal firmware, nothing to do with EFI. If the board actually boots up, then you can use Muerto's SMC flashing tool to reprogram the SMC for an A1502.
    https://github.com/MuertoGB/SMCTool
    • AlexVG
      • Apr 2022
      • 138
      • SPAIN
      Thank you.
      Very interesting.
      It starts without reprogram the SMC, but backlight is missing.
      I guess it's another kind of problem, Is it?
      • AlexVG
        • Apr 2022
        • 138
        • SPAIN
        It's screen problem(((
        Main has 52V.
        Thank you for your help.
        • AlexVG
          • Apr 2022
          • 138
          • SPAIN
          I checked the main with good working screen - it doesn't work.
          It's the SMC issue.
          Need your help.
          • AlexVG
            • Apr 2022
            • 138
            • SPAIN
            I found the problem.
            It's very easy and common - water damaged inside of LVDS connector.
            Thank you!
            • reformatt
              • Feb 2020
              • 1550
              You do need to program the SMC for the right model BTW. When using 820-3437 in 820-00165 the audio doesn't work correctly for example. Not sure what happens with a A1466 SMC in a Pro as I've not done it. But nice to know it works directly.
              • AlexVG
                • Apr 2022
                • 138
                • SPAIN
                Yes, thanks to your link, I successfully changed the SMC firmware.
                It works correctly now.
                (the fan was not working properly)
                Thank you again!
