this computer has no signs of liquid damage. It will power up with both the charger and the battery attached but it doen't start with the 60 watt charger without the battery being attached. When it starts up the vcore shows up for a few seonds then it's powers down and then powers up again. it does seem to charge the battery.. It's hard to troubleshoot because the battery is glued to the casing.
a1502 820-4924 doesn't post and won't power up with the charger alone
by rsa4092Acer Nitro 5 - AN515-54-52PY - LA-H501P
Hello, Iām having a problem with my Acer Nitro 5 laptop, which has a Compal LA-H501P motherboard.
Initially, the CPU power regulator was replaced because the computer shutdown unexpectedly, and couldn't be turned on, the service centre diagnosed a short circuit in the CPU power regulator, replaced it and laptop was working. After about two months, a new problem arose ā the laptop would shutdown under heavy load, even when connected to charger. In addition, the battery was charging very slowly ā or rather, discharging ā despite... -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
by itnormOriginal charger light goes out when plugged into the laptop (both usb-c ports). Original charger works fine with charging another laptop. Universal charger's light does not go out (but it flickers) and does not charge this laptop either.
Installed a new battery (which had about 60% out of the box)so that there is a charge and so I can work on the laptop. The original battery probably works just fine, but it has lost all its charge and therefore does not afford the chance to work on the laptop.
Pulled the cmos battery to reset bios to default. When the new battery was... -
by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
So the battery is backfeeding the charger and being drained.
How can I prevent... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
- Loading...
