iPad 9th generation Battery issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    iPad battery seemed defective, it would charge then once it turned on it wouldn't charge more. After ordering a battery it would charge then drain very quickly (1% drain every 20 seconds) it then wouldn't take a charge then take a charge when it hit a certain level. I'm assuming it is a defective battery, it doesn't turn off when unplugged but seems faulty. Sometimes when I plug it back in it doesn't even take a charge and keeps draining then all of a sudden it charges. Am I missing something?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: iPad 9th generation Battery issue
    You seem to have charging issues before and after the battery change.
    Where did you get it ? Perhaps it's the charging ic/circuitry.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Open box return pallet.
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Both batteries seem to not charge however the other battery charged but drained very quickly it seemed.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Installed older battery turns on but doesn’t charge. But turns on then shows 0% all the time but holds a charge then shows 20% afterwards. Defective batteries maybe?
          sigpic
          • mon2
            • Dec 2019
            • 14660
            Carefully check the voltage to ground of the smbus lines (SCL and SDA) on the battery connector.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Odd request but do we have a schematic for this board
              sigpic
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
              • razenxd
                How can I charge that battery pack?
                by razenxd
                it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                Now, I have noticed a few things.
                The "dead" battery, while connected to charger and NOT Charging will...
                12-05-2024, 06:11 AM
              • code share
                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                by code share
                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                Here's what I've tried so far:
                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                • Booted successfully on AC power only with the battery disconnected
                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                • Battery
                04-21-2025, 12:50 PM
              • ruletero
                Acer a515-43 low battery charge voltage
                by ruletero
                Hi
                Acer A515-43
                LA-H801P
                Fail: Does not charge battery, has low voltaje on connector.
                Laptop didn't want to turn on, only charge led blinked.
                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                10-24-2022, 02:31 PM
              • GeirAndersen
                iPad .pcb file collection
                by GeirAndersen
                I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                IPAD COLLECTION 1
                +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                12-09-2024, 09:28 AM
