disable ram at nm-c931 thinkpad T14
  • Le phu lam
    • Jul 2020
    • 7
    • Việt Nam
    please help me to remove ram onboar with bios or id on schematic (with schematic and bios)
    Schematic and BV: https://www.badcaps.net/forum/showth...72#post1215772
    Last edited by Vesko356; 06-07-2023, 05:59 AM. Reason: Attached schematic removed and replaced with link. Bios dump removed.
  • streft
    • Mar 2014
    • 9
    • Azerbaijan
    Hello, did anyone manage to disable the ram?
    • dahnking
      • Apr 2018
      • 261
      • kenya
      Have you managed to solve? i have the same issue
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try this bios https://www.badcaps.net/filedata/fetch?id=3230991
        Report back if it works.
        • GigaBlyate
          • Oct 2023
          • 19
          • Россия
          no work
          • laptopgreen
            • Aug 2017
            • 26
            • VN
            Hello, anyone has solution for this problem?
            • judamex
              Active Member
              • Jan 2021
              • 185
              • Mexico
              Up your BIOS backup i try to disbale.
                • 21606
                All bios requests should be posted in the "Bios requests ONLY!" sub forum.There`s already a dedicated " On Board Ram Disable via Bios Editing" thread,and an automated script in another thread to disable DDR4 ram.
                https://www.badcaps.net/forum/troubl...63#post3172363
                • huzo
                  • Sep 2014
                  • 185
                  • CROATIA
                  Did anyone figure it out how to disable this?? i have a board with 32gb samsuing...and haven't got a clue how to disable it...
                  • huzo
                    • Sep 2014
                    • 185
                    • CROATIA
                    Come on guys, there is a parto of the schematic in the first post, help us less fortunate to earn some bucks!Is it even a ram issue?
                    • mon2
                      • Dec 2019
                      • 14631
                      Never attempted this before but it appears that you only need to strap as per the posted chart in post #1.
                      1) Take a pic of each resistor before starting so you can reverse the process, if necessary.
                      2) Remove resistors R1106, R1107.
                      3) Stuff resistors R1108, R1109, R1110. You can solder blob these pads to achieve the same 0 ohm resistor.
                      The above strappings should build up the binary code = 00111b = 07h in the above strap chart.
                      Attempt it and post your updates.
                      • huzo
                        • Sep 2014
                        • 185
                        • CROATIA
                        Hi mon2, tnx for sharing ,will give it a try, but i have samsung version 16gb k4abg165wa mcwe...i will post a full page from the schematics,so maybe you can help with my version? Click image for larger version
                        • sidgwick
                          • Feb 2025
                          • China
                          In order to build 00111b, R1106/R1107 should be staffed and remove R1108-R1110 ?
                          I try both 00111b and 11000b, but nothing works.
                          • sibernetic
                            • Aug 2024
                            • 19
                            • Türkiye
                            Hello... I want to disable the onboard RAM on Lenovo ThinkPad T14 Gen 1 laptop motherboard, NM-C931, but I've never been able to do it.
                            The motherboard has an Intel processor and Samsung 8GB of integrated RAM.
                              SMDFlea commented
                              Editing a comment
                              Thread merged.
                          • sibernetic
                            • Aug 2024
                            • 19
                            • Türkiye
                            • sibernetic
                              • Aug 2024
                              • 19
                              • Türkiye
                              • sibernetic
                                • Aug 2024
                                • 19
                                • Türkiye
                                .... any help
                                • lucaszmn
                                  by lucaszmn
                                  Problem:
                                  Initial Findings:
                                  • I concluded that the
                                  08-12-2025, 03:01 PM
                                • MaxonDomkrat
                                  Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                  by MaxonDomkrat
                                  Hi everyone.
                                  I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                  07-30-2025, 01:27 PM
                                • 1g0r
                                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                  by 1g0r
                                  First, the data in brief:
                                  Manufacturer: Lenovo
                                  Model: ThinkPad L15 G3 21C3-0016GE
                                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                  IC Bios 1: MX77L25650F
                                  IC Bios 2​: MX25L25673G
                                  EC Chip: NPCX997KAABX
                                  So far I've been a silent reader, but now I need your help
                                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                  01-18-2025, 02:39 AM
                                • RMDUiFT
                                  Should I buy a Lenovo Thinkpad E495 with bios password?
                                  by RMDUiFT
                                  Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                  I have a few questions:
                                  • If I would buy this laptop and have
                                  08-25-2024, 09:00 AM
                                • Mr.Ultimate
                                  Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                                  by Mr.Ultimate
                                  Hi everyone, hope to get someone to help and modify bios rom for me.
                                  I need to disable dedicated nvidia graphics chip permanently.
                                  GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                                  Ideally if it was disabled from bios at preboot.
                                  I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                                  08-06-2024, 05:15 AM
