A1502 - unable to run diagnostics
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    A1502 / 820-4924-A. Unable to run diagnostics or recovery over internet.
    Getting errors -1003F or -1003D shorty after inputting wifi details.
    Runs Catalina & Big Sur fine. EFI updated to latest for the model (481).
    I can register it with my iCloud / FMA.
    Tried replacing the SSD, installing fresh OS, replacing wifi card.
    Tried different 'internet routes' (APs). Tried disabling FMA.
    Even stood up a custom AP where I can sniff traffic - macbook successfully looks up osrecovery.apple.com and connects on port 80 (dumping below some HTTP chatter). After these few requests it disconnects and above errors show up.
    What gives? What else to try?
    Code:
    GET / HTTP/1.1
    Host: osrecovery.apple.com
    Connection: Close
    User-Agent: InternetRecovery/1.0
    Server: dlb/1.0.2
    Date: Wed, 31 May 2023 20:42:34 GMT
    Content-Type: text/plain;charset=us-ascii
    Content-Length: 0
    Connection: close
    Set-Cookie: session=1685566054~C5D3335BDE532000037245D32A7023D201C2F9AF53492FC64C492FEBF9639226; Domain=osrecovery.apple.com; Path=/; HttpOnly
    Strict-Transport-Security: max-age=31536000; includeSubDomains;
    Via: 17.42.252.38
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    Re: A1502 - unable to run diagnostics
    I've just noticed that the logic board has a different serial to that of the case.
    Is it possible that serial number is stored elsewhere (say, touchpad?) and diagnostics/recovery fails because of that?
    • kevingill
      • Jun 2013
      • 152
      • England
      I'm not aware of serial in the trackpad and I've changed a few over the years.
      I've even changed the motherboard serial several times and it's still worked OK.
      Do you have an ethernet adapter to try instead of WIFI?
      • cruiser_
        • Nov 2019
        • 124
        • Ireland
        ok thanks for the confirmation. I do not have a usb ethernet adapter. This is more of a nuisance than a real problem, I just like my merchandise to be 100%
        There is a lot of flux on SPI chip, someone must have played with it.
        One last lead I have is the serial#, it beings with C10 - some serial number decoders I found say it's an unknown location. Might try to replace it with C02.
        I wonder if the diag/recovery code is stored in SMC or EFI. Did not find any references to osrecovery.apple.com in available EFI or SMC dumps.
        Have you ever seen serials starting with C10? Maybe the code starts but then goes on to validate/lookup the internals and stops.
        • cruiser_
          • Nov 2019
          • 124
          • Ireland
          Ok I am 99% certain this is down to a borked firmware file. I dumped it via linux with flashrom...
          - fsys checksum is invalid
          - hardware code is different
          - country code in serial is unknown (C10)
          How this boots and works 'fine' is beyond my understanding
          Code:
          xxx:/tmp$ ./macserial -i C10PF6VQFVH3
              Country: C10 - Unknown, please report!
               Year:  P - 2015
               Week:  F - 12 (19.03.2015-25.03.2015)
               Line: 6VQ - 1418 (copy 3)
               Model: FVH3 - MacBookPro12,1
            SystemModel: MacBook Pro (Retina, 13-inch, Early 2015)
               Valid: Possibly
          • kevingill
            • Jun 2013
            • 152
            • England
            Ah, that doesn't look good.
            Just change the serial to the same as the base plate serial and then the pair will match up.
            Probably best get a clean ROM from this forum and set the serial number in that.
            Hopefully that will get it going properly.
            The diagnostics are on a partition of the SSD, so you'll need an install of your favourite MACOSX.
            • reformatt
              • Feb 2020
              • 1479
              You need to fix the Fsys block checksum in the dump after you change the serial number. Piernov has a video on YouTube on how to do it with UEFI tool and hex editor.
              Diagnostics doesn't reside on the SSD anymore, it's downloaded via Internet Recovery. Invalid serial and bad checksum would explain why its not working.
              • cruiser_
                • Nov 2019
                • 124
                • Ireland
                The board inside of this case is 820-4924-09. From the files I found for this model, all of them had FVH3 as model code.
                Each and every time I changed the serial to the one on the case (it indicates FVH5 model), the board wouldn't start - and cycled.
                However... when I updated the serial in the 'original' dump (which was FVH3...) the board booted, new serial was visible in OS, however the diagnostics wouldn't run UNLESS i put 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:MLB/HW_MLB values in NVRAM.
                Tried clearing VSS/SVS - no boot.
                So I spent hours de/resoldering/programming the SPI, checked multiple files and I'm a bit stuck... some sort of validation of the serial/model is kicking me in the butt :|
                • piernov
                  NVidia bumpgate
                  by piernov
                  Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                  Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                  May complete this post at a later date with more details.
                  Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                  03-27-2021, 10:34 AM
                • chappers
                  Nvidia MATS help please - 33 errors on two cards?
                  by chappers
                  I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
                  I have 3 graphics cards in the house.
                  My son's - Palit GTX 1080 used for 3D games constantly.
                  Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
                  Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
                  Running MATS on my son's GTX 1080 gives a pass with no errors.
                  Running MATS on my GTX 1080 gives...
                  08-09-2023, 01:28 PM
                • master_haze86
                  A1990 820-01814-A dead not charging - need help with diagnostics.
                  by master_haze86
                  Good day everyone,
                  Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
                  The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
                  09-13-2025, 06:01 PM
                • konter
                  ACER Nitro 5 AN515-55-774Z errors in mats
                  by konter
                  ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1))
                  Intel Core i7-10750H
                  RTX 2060 6GB GDDR6
                  There was a short circuit on the video memory power supply. Replaced all memory with new memory. The short circuit is gone.
                  Now the laptop turns on and works. But heats up a lot. Turned on with external cooling. In Windows the video card is detected but after installing the correct drivers it gives error 43.
                  In MATS test on 5mb writes a lot of errors on all memory channels on the record. (Attached report)
                  When testing on 2mb of memory built into gpu...
                  10-19-2024, 11:24 AM
                • AlexVG
                  Macbook A1502 SMC replaced. Can I use SMC A1466? Do I need SPI clean ME?
                  by AlexVG
                  Good evening.
                  I replaced SMC on Macbook A1502.
                  I have had SMC from A1466 only. It's the same but obviously has different program.
                  Is it enough to clean SPI with
                  https://www.badcaps.net/forum/troubl...-bios?t=100913
                  and change SN?
                  Thank you.
                  08-16-2024, 02:12 PM
