iPad 7 A2197 - no power
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Hello, I have iPad that won't turn on. With connected battery there is about 450mA constant current draw. I dissasembly PCB, when I connect it without battery, there is about 20mA current draw.
    No signs of liquid damage etc.
    What should I check, please?
    Thanks for your help.
    Martin
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Re: iPad 7 A2197 - no power
    Same problem as described here : https://www.badcaps.net/forum/showthread.php?t=119040
    • mon2
      • Dec 2019
      • 14659
      Re: iPad 7 A2197 dead
      Is the current spiking to this target current draw?
      You likely have a shorted part on the battery side.
      Remove all power, check the resistance to ground at the battery+ connector but without the battery connected.
      What is the resistance?
      Watch this video:
      https://youtu.be/xqki4qHCJuw
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        Hello, thanks for reply. Current draw is constant all the time. Resistance on battery connector + to ground is 4 Mohm.
        Already checked this video, but I think it's another case.
        Last edited by martyjelen; 06-01-2023, 06:57 AM. Reason: mistake-wrong pin measurement
        • mon2
          • Dec 2019
          • 14659
          See attached. Review with caution.
          Adding (Ayman who has some great videos as well):
          https://www.youtube.com/watch?v=uWgPPNsdNAc
          Update (again) - this video confirms there is a shorted component on the board. Remove all power. Probe all visible caps' resistance to ground. No power during these tests. Hunting for a low resistance reading.
          https://www.youtube.com/watch?v=4xDV_BvcVFU
          • martyjelen
            • Mar 2023
            • 127
            • Czech republic
            These are have very low resistance, about 12ohms.
            edit: also these
            • mon2
              • Dec 2019
              • 14659
              Now locate these caps in the boardview file.
              Then again in the schematic.
              Then we will know to which power rail these parts are linked. Then we can determine if the low resistance is normal or not. Once at this stage, it may be worthwhile to inject a low voltage to determine who heats up.
              Alex's video mentions anything in the ~400-450mA is a short... regardless of the model.
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                • mon2
                  • Dec 2019
                  • 14659
                  Skip this batch of parts - each is linked to a low voltage rail and respectively, is expected to be a low resistance rail.
                  Continue your hunt. Best to use resistance mode checks - not diode mode to locate the defective cluster of parts. That is, for example, a 100 ohm resistance will not tone beep in diode mode but yet is considered a short if it is this low of a value on a 3v3 rail.
                  For this reason, measure the true resistance to ground of each cap on the board.
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    There are many caps under the shield which I can't reach. But every cap I measured looks OK.
                    • elecsoluces
                      • May 2020
                      • 66
                      • France
                      no power : check first PPBATT_VCC and PPVDDMAIN.
                      Inject 4V/3A to PPBATT_VCC and try to boot the device. Report the current draw on your power supply.
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        There is nothing on PPBATT_VCC. I can't find PPVDDMAIN nor PPVDD_MAIN in schematics.
                        Did you mean PPVCC_MAIN?
                        Current draw is 0A.
                        • elecsoluces
                          • May 2020
                          • 66
                          • France
                          "There is nothing on PPBATT_VCC" what do you mean?
                          Connect your power supply to PPBAT VCC and press power button (long press) current draw is 0. Did you connect ground?
                          PPVCC_MAIN and PPBATT_VCC have same voltage value
                          • martyjelen
                            • Mar 2023
                            • 127
                            • Czech republic
                            I'm sorry. Measured it wrong. There is 4V on PPBATT_VCC and also 4V on PPVCC_MAIN.
                            When I press power button, there is 12mA current draw.
                            • elecsoluces
                              • May 2020
                              • 66
                              • France
                              • martyjelen
                                • Mar 2023
                                • 127
                                • Czech republic
                                Like I said. Without battery connected - It's about 12mA
                                With battery connected - It's about 450mA
                                • mon2
                                  • Dec 2019
                                  • 14659
                                  How and where are you measuring the current draw?
                                  Are you using a dc power supply to mimic the battery?
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    I have a power supply where is connected USB > lightning cable.
                                    When I connect it this way (without battery) - current draw is 20mA
                                    When I connect it this way (with battery) - current draw is 450mA (constant)
                                    When I connect power supply directly to battery pin. Current draw is 12mA
                                    • mon2
                                      • Dec 2019
                                      • 14659
                                      The boardview file will offer diode mode measurements for the charge port connector.
                                      Suggest to remove all power and compare your readings against reference to check if the TriStar chip is ok or not. Believe that logiwki / repairwiki will also offer the diode readings of notable points on the logic board.
                                      PS: have you tested with another known good battery?
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        Unfortunately, I don't have diode mode measurments in my file. I wonder if it's the same as ipad 5 charging port. Looks similair. But I have differnet values.
                                        https://logi.wiki/index.php/iPad_Dio...e_Measurements
                                        • willis6732
                                          A2197 / Ipad 7th Gen / 2019 - No Power / Low Current Draw
                                          by willis6732
                                          Ive been working on this ipad for a little while now. CPU reballing is a common issue needed on this model.
                                          I wanted to try and verify there is not a PMIC Problem before reballing the CPU.
                                          Powering 4.2V at the battery gives a 0-1ma Draw
                                          Pressing the power button it jumps to 18+ma and settle at 15ma
                                          Ive attached my Readings for many of the power rails.
                                          THis is how the columns are layed out:
                                          Ohms/ Diode / Voltage After power button Press / Injecting Voltage Reading
                                          In the second...
                                          10-13-2023, 04:43 PM
                                        • GeirAndersen
                                          iPad .pcb file collection
                                          by GeirAndersen
                                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                          IPAD COLLECTION 1
                                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                          12-09-2024, 09:28 AM
                                        • proxneo
                                          iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
                                          by proxneo
                                          Dear reader
                                          TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
                                          I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
                                          12-01-2023, 04:14 AM
                                        • jolivares
                                          NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
                                          by jolivares
                                          I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
                                          This is what i found until this moment:
                                          1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
                                          2) no short circuit in lines VCC_MAIN, VCC_BATT.
                                          3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
                                          4) the current draw from the power supply, without battery, is about 26mA from the charging...
                                          07-15-2024, 09:24 AM
                                        • waterchill
                                          iPad 7 A2197 dead
                                          by waterchill
                                          So I have here this board which is dead. Current without battery is about 25mA with battery 470mA. I checked all voltages, missing this one:
                                          PPVDD_GPU
                                          PPVDD_GPU_SRAM
                                          PP1V8_TOUCH_EXT_SW
                                          PP3V0_ALS
                                          PP3V3_ACC
                                          PP1V25_REAR_CAM
                                          I don't know if these voltages are coming up, when iPad is booting. I have changed the PMIC without any result.
                                          The PPVDD_GPU line have 8,2 ohms and in diode mode it is short. I have injected 0,8v in this line, only the A10 chip is getting slightly warm.
                                          Any ideas?
                                          05-12-2023, 02:46 AM
