iPad 7 A2197 dead
  • waterchill
    • Sep 2021
    • 33
    iPad 7 A2197 dead
    So I have here this board which is dead. Current without battery is about 25mA with battery 470mA. I checked all voltages, missing this one:
    PPVDD_GPU
    PPVDD_GPU_SRAM
    PP1V8_TOUCH_EXT_SW
    PP3V0_ALS
    PP3V3_ACC
    PP1V25_REAR_CAM
    I don't know if these voltages are coming up, when iPad is booting. I have changed the PMIC without any result.
    The PPVDD_GPU line have 8,2 ohms and in diode mode it is short. I have injected 0,8v in this line, only the A10 chip is getting slightly warm.
    Any ideas?
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Re: iPad 7 A2197 dead
    Hello, I have exact same problem. Did you solve it?
    • AlexVG
      • Apr 2022
      • 135
      • SPAIN
      Hi.
      I have absolutely the same problem on
      A1893 and A 2179 boards
      Originally posted by waterchill
      PPVDD_GPU
      PPVDD_GPU_SRAM
      PP1V8_TOUCH_EXT_SW
      PP3V0_ALS
      PP3V3_ACC
      PP1V25_REAR_CAM
      Have somebody managed to solve that?
      Thank you.
      • GeirAndersen
        iPad .pcb file collection
        by GeirAndersen
        I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
        Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
        IPAD COLLECTION 1
        +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
        +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
        +---iPad mini3 820-00008(A1599) 820-00002(A1600)
        +---iPad mini4 820-00180(A1538) 820-00177(A1550)
        +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
        +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
        12-09-2024, 09:28 AM
      • proxneo
        iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
        by proxneo
        Dear reader
        TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
        I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
        12-01-2023, 04:14 AM
      • willis6732
        A2197 / Ipad 7th Gen / 2019 - No Power / Low Current Draw
        by willis6732
        Ive been working on this ipad for a little while now. CPU reballing is a common issue needed on this model.
        I wanted to try and verify there is not a PMIC Problem before reballing the CPU.
        Powering 4.2V at the battery gives a 0-1ma Draw
        Pressing the power button it jumps to 18+ma and settle at 15ma
        Ive attached my Readings for many of the power rails.
        THis is how the columns are layed out:
        Ohms/ Diode / Voltage After power button Press / Injecting Voltage Reading
        In the second...
        10-13-2023, 04:43 PM
      • kingskie
        iPad A2378 dead no charging
        by kingskie
        i have an iPad A2378 dead no charging.
        disassembled and found out that 343S00389-A0 ic was hot so i took it out. after that i measure but the caps ( you can see in the picture i attached) still short to ground.
        does anyone has a clue?...
        05-09-2023, 09:35 PM
      • martyjelen
        iPad 7 A2197 - no power
        by martyjelen
        Hello, I have iPad that won't turn on. With connected battery there is about 450mA constant current draw. I dissasembly PCB, when I connect it without battery, there is about 20mA current draw.
        No signs of liquid damage etc.
        What should I check, please?
        Thanks for your help.
        Martin
        06-01-2023, 03:10 AM
