HP820 G1 Not charging unless powered off
  • alkuentrus
    • Aug 2012
    • 28
    • Portugal
    Hi guys.
    have this weird laptop that only charges battery if powered off.
    Also, if battery is not present, laptop doesn't power on (flash grey led at 1 Hz)...
    Any ideas?
    Best regards,
    David
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: HP820 G1 Not charging unless powered off
    Check first and second mosfet for internal short and give the readings from the pins on your charging ic.
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • SluggerB
      Help with trying to fix phone that is not charging (Pics inside)
      by SluggerB
      I have two TCL A30 phones.
      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
      New Phone: Works fine, bought as a donor board to try and repair Old Phone
      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
      08-12-2024, 08:11 AM
    • Wang Tingting
      Acer Nitro 5 AN515-57-536Q not charging
      by Wang Tingting
      I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
      report is also good for battery.
      Following https://www.badcaps.net/forum/troubl...arging-circuit,
      • DCIN/VCC: 19.1
      • ACIN/ACDET: 3v
      • REGN/VDD: 6v
      • CMSRC : 19v
      • ACOK: 3.3v
      • ACDRV: it is 19v, not 25V(when charging, the ACDRV
      09-10-2025, 01:46 PM
    • abrahim110
      [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
      by abrahim110
      🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
      I have an Acer Aspire 5 A517-52G-53NB laptop.
      The onboard (soldered) RAM was faulty, so I physically removed the chip.
      I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
      ✅ System status:
      • BIOS mod is done (SPD removed)
      • Laptop boots to Windows normally
      • RAM is detected and stable
      ❌ Problem:
      The battery is not charging:
      • Power adapter
      08-06-2025, 06:15 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
