Hp 840 ram issue
  • motanya
    • Nov 2021
    • 160
    • Kenya
    Hp 840 ram issue
    This laptop beeps 3.2 and 3 caps lock blinks, which normally for hp indicate a Ram issue. I have changed several working rams and bios but the issue is yet to be resolved what might be the problem?
  • mon2
    • 14399
    Re: Hp 840 ram issue
    Check your memory socket contacts to be sure they are clean. Use IPA (alcohol) to clean them.
    Be sure the solder joints on the memory socket are ok.
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • armands0212@gmail.com
      Alienware 15 r2 error 4 beeps code.ram issue
      by armands0212@gmail.com
      Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
      Ram sockets looks fine as well,cleaned them and carefully inspected
      So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
      05-23-2023, 12:48 PM
    • cheeky2
      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
      by cheeky2
      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
      01-08-2024, 05:56 AM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
