Asus X58c some distortion on output of ALC660 ic
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3572
    • slovakia
    Hello.
    Have this old Asus X58c that have some distortion on output of ALC660 sound ic. distortion is in SPK and Headphone.
    i dont have spare ic, but it looks like a bad ic. have anybody some experience with this error?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X58c some distortion on output of ALC660 ic
    Got buzzing sound in both headphone/speakers on dell 3567 motherboard. Culprit was the IC itself.
    • piernov
      • Jan 2016
      • 4435
      • France
      Exclude software issue first, IIRC this generation of Realtek audio codecs have poor drivers for modern Windows (ALC880 too). May need to make sure all effects/enhancements are disabled in the audio control panel.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3572
        • slovakia
        offcourse i did all software mods. work on win xp.
        • FrancescoV
          Onkyo HT-R390 no sound output, video output ok
          by FrancescoV
          Good morning everyone,
          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
          The firmware reported is the following:
          M:1.00/11107BLP
          D:?.??/????????
          O:1.00/11107AL
          The DSP firmware given the question marks seems corrupt.
          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
          05-11-2025, 02:59 AM
        • Jedi134
          Uniden bearcat UBC 360clt no sound output
          by Jedi134
          Hi I have inherited the above desktop scanner, all seems to work correctly but there is no sound output. The only sound I do get from the speaker is the beep confirmation when you press a key. No output from the headphone socket either. Not even radio static with squelch fully turned down, tried a reset by holding 2, 9, and hold buttons but still no sound, does anyone have any experience with these scanners, thanks.
          05-13-2024, 04:12 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • Rupsenkind
          Yamaha RX-A1030 working, no sound output
          by Rupsenkind
          Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
          Just to recap:
          No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
          07-10-2022, 03:15 AM
