Uniden bearcat UBC 360clt no sound output
  • Jedi134
    • Nov 2015
    • 14
    • Uk
    Hi I have inherited the above desktop scanner, all seems to work correctly but there is no sound output. The only sound I do get from the speaker is the beep confirmation when you press a key. No output from the headphone socket either. Not even radio static with squelch fully turned down, tried a reset by holding 2, 9, and hold buttons but still no sound, does anyone have any experience with these scanners, thanks.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Open it up and post some high resolution straight shot pictures of the board(s) and add it using the attachment function.
    In the mean time you can read this:
    https://www.badcaps.net/forum/troubl...o-audio-repair
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      by the sounds of it it must have an RX problem, since you can hear beeps.
      • Jedi134
        • Nov 2015
        • 14
        • Uk
        Yes could well be RX problem as won't grab any frequency, not even a strong local radio station, just keeps on scanning, the beep however is crystal clear..
        I have uploaded some photos as asked, maybe you can point in the right direction.
        • R_J
          • Jun 2012
          • 9607
          What are you using for an antenna? the telescpoing one that comes with it?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Measure the resistance between the centre pin of the BNC connector (antenna) to the outside shield. Try using a AM loop antenna to receive something on the AM broadcast band. See what that does. On the first picture is all your RF and audio stuff. The 450khz receiver (AM/FM demodulator) is the JRC2552 IC next to the metal can. I wonder if it is just a certain band not working or if everything is dead. If everything is dead things aren't looking good unless you got a donor or spare parts (besides if you measure a short on the antenna).
            I do have a BC340CLT here that I just fixed. On this one was a cap bad. On your picture it would have been the cap that is black. But I doubt it.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8340
              Here is a schematic for a UBC355CLT. Close enough for the RF path's anyway...
              • Jedi134
                • Nov 2015
                • 14
                • Uk
                Yes but I would have thought this would pick something up especially a strong radio station, I will try something else just to rule it out though.
                • Jedi134
                  • Nov 2015
                  • 14
                  • Uk
                  Same with AM band and loop antenna won't lock onto any frequency
                  The black cap next to the heatsink with a KIA78/R09PI strapped to it. Some kind of voltage regulator. What was the fault you had to warrant replacing this cap? Looks like a 100uf 25v.
                  also what do these 2 pots do. RT2 and RT3
                  No short across antenna reading 1.4 Meg ohms
                  • Jedi134
                    • Nov 2015
                    • 14
                    • Uk
                    Thanks will have a look at them. Could it be a squelch problem, ie it's defaulted to max and is just by passing the scanned frequency??
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      The caps around the 9V regulator are always a problem on the older scanners with long run times,
                      O.k. So you have no short on the antenna, good! Did you check the other bands? This step is important look at the schematic. The receiver has 5 bands! Each band is tuned for a specific frequency range.
                      So do you have a problem with the switching in between bands, a blown IF amps, PLL unlock, a mixer missing or that RX IC bad? Don’t just screw around with pots that you don’t know what they do, because then you probably need an alignment and you need specific tools to do so.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8340
                        I doubt that.
                        I would be spraying an RF signal into the 455khz IF. If something comes out the speaker, it will tell you if the front end is damaged or not. Don't forget to check the 10.8Mhz IF.
                        • Jedi134
                          • Nov 2015
                          • 14
                          • Uk
                          Result it was the squelch pot.. reading 8Meg ohm in both directions, so I swapped over too the other pin.. I'm receiving the world now...only my squelch operates in the opposite direction. Thanks for all you help anyway.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8340
                            That's a rare one. Never encountered that on a Uniden scanner. Never the less a good fix!
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                            • Rupsenkind
                              Yamaha RX-A1030 working, no sound output
                              by Rupsenkind
                              Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
                              Just to recap:
                              No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
                              07-10-2022, 03:15 AM
                            • CapLeaker
                              Bearcat 300 scanner no display, has audio and squelch repair
                              by CapLeaker
                              I found an old Bearcat 300 scanner that had no display, but the audio and squelch worked, over at my workplace. This unit has a lot of hours on it. It had some capacitor replacements and other mods done to it too before I found it. To troubleshoot this problem, the usual is to check the +25v and -30V and replace C98 on the main board. That should fix it. There is also a case of a shorted button board (just unplug that ribbon cable and the display should work again). Spoiler alert! Was not the case on this one.
                              My display didn't work, because I had a missing -10V on the display...
                              09-09-2024, 10:24 AM
                            • r2digital
                              Boston Acoustic MSUB no sound output(pics)
                              by r2digital
                              The off/on/auto switch was busted so i forced it into auto mode and now the blue light comes on but i don’t get any audio output. Does anyone one have any experience repairing this amplifier? I looked it over, checked some the of output transistors, some of the power resistors and cleaned that nasty conductive epoxy glue stuff off but not having much luck in the trouble shooting department.
                              I did however find a part of the PCB that was discolored from heat...
                              03-22-2024, 06:00 PM
                            • proxneo
                              Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
                              by proxneo
                              Dear reader
                              I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
                              12-02-2023, 09:27 AM
