can you help me with 820-01700-A missing 20v and 12v
  • mgjini
    • Sep 2017
    • 199
    • united kingdom
    hello all
    i have been trying for days to resolve this board 820-01700-A, i have been reading the logiwiki but i still can not find the issue with this board, the board looks clean, and i have been inspecting it and i don't see any water damage or anything like that
    https://repair.wiki/index.php?title=...e_view_desktop
    on all 4 ports i get 5v i am missing 20v and 12v, i have checked the cd32s like another person was asked here to do so https://www.badcaps.net/forum/showthread.php?t=118994 , red probe on ground and black on the capaictors ub40 ub30 u3100 u3200 and they are giving 0.568v , with power attached i am getting 5v and all the above
    I also connected laptop with another macbook and run apple configurator 2 to see if laptop was in dfu mode but the other macbook did not detect the macbook
    PPBUS_G3H 0.586v with power attached
    PP3v3_G3H_RTC_X 0v
    PP3v3_G3H_SOCPMU 0v
    PP1V5_UPC_TA_LDO_CORE 0.547v
    PP1V5_UPC_TB_LDO_CORE 0.547v
    PP1V5_UPC_XA_LDO_CORE 0.538v
    PP1V5_UPC_XB_LDO_CORE 0.543V
    PP3V3_UPC_TA_LDO 0.514V
    PP3V3_UPC_TB_LDO 0.524V
    PP3v3_UPC_XA_LDO 0.521V
    PP3V3_UPC_XB_LDO 0.520V
    Any help i would be grateful
  • mon2
    • Dec 2019
    • 14003
    Re: can you help me with 820-01700-A missing 20v and 12v
    PPBUS_G3H 0.586v
    Rail is likely shorted. Remove the fuse on this rail. Remove all power. Measure the resistance to ground on each side of the removed fuse but on the PCB pads.
    Post your measurements.
    • mgjini
      • Sep 2017
      • 199
      • united kingdom
      on oms mode black proble on the ground and red on each side of the pads i am getting 73oms on both sides of fuse f7000 , each side of the fuse the probes 0oms, and is shorted
      • mon2
        • Dec 2019
        • 14003
        Remove the fuse at F7000 and measure again.
        • mgjini
          • Sep 2017
          • 199
          • united kingdom
          hi the measuruments above was when i removed the fuse f7000, with the fuse back on is short again, diode mode red ground black on each side 0.454v , on ohms mode red on ground black on each side of the fuse 3.265 mΩ
          • mon2
            • Dec 2019
            • 14003
            In post #3 - 73 ohms to ground? Can you confirm?
            Is the fuse now removed from the board?
            If yes, power up (without this fuse) and check the voltage of the PPBUS_G3H to ground.
            • mgjini
              • Sep 2017
              • 199
              • united kingdom
              it is 015.0 ohms to ground on both sides of the pad fuse f7000, i powered it up and measured without fuse and i am gettig 0.126 v ppbus_g3h
              • mon2
                • Dec 2019
                • 14003
                Sorry - forgot that are 2 fuses on this PCB.
                Locate and remove F7001 as well.
                Then check the resistance again on each side of the fuse pads (either one is ok).
                • mgjini
                  • Sep 2017
                  • 199
                  • united kingdom
                  hi, sorry for the late replys, i have removed the f7001, and i have 12v on one side and nothing on ppbus_g3h
                  • mon2
                    • Dec 2019
                    • 14003
                    Good. Your ISL chip is working.
                    Remove all power. Check the resistance to ground of the side of the fuse that is shorted.
                    What is the resistance?
                    Do you have an adjustable power supply?
                    • mgjini
                      • Sep 2017
                      • 199
                      • united kingdom
                      it says 0.15ohms and yes i have adjustable power supply, i applied some power and the only thing that gets noticed on thermal camera is this chip u6420, after removing this chip now i get 3.45 m ohms one the 12v side and on the ppbus_g3h side i get much higher readings now like 2.56 m ohms and different measurements but all above 1.00 m ohms
                      • mgjini
                        • Sep 2017
                        • 199
                        • united kingdom
                        after removing this chip u6420 and replacing it i now have on both sides 12.26v but still no power i wonder if there is something wrong with isl chip
                        • mon2
                          • Dec 2019
                          • 14003
                          No, ISL is fine but it is not being instructed to kick upto 12v6.
                          See here:
                          https://boards.rossmanngroup.com/thr...s-12-3v.62475/
                          Check the SMBUS rails on the ISL chip (SDA / SCL). What are their voltages to ground?
                          • mgjini
                            • Sep 2017
                            • 199
                            • united kingdom
                            Hello there, sorry for not replying earlier, my measurements are same as this guy who posted on rossmangroup, now I am just waiting to see if I can find another MacBook to see again if MacBook is in dfu mode
                            • mgjini
                              • Sep 2017
                              • 199
                              • united kingdom
                              hi i connected macbook with another macbook and it doesn't show on apple configurator 2, so i don't think is in dfu mode
                              reading on the link you provided
                              UPC_I2C_INT_L = 0v
                              i don't know if it is worth mentioning pp3v3_g3h_socpmu 0.328v c7891/92
                              i don't know if i now should move the cd32 chips as in the forum
                              • ugamazing
                                • Jun 2013
                                • 165
                                • usa
                                You should first confirm the SSDs are not shorted--a common issue with the 01700 and a very common cause of shorted ppbus_g3h.
                                • mon2
                                  • Dec 2019
                                  • 14003
                                  Remove all power. Meter in resistance mode.
                                  Measure the resistance to ground of each rail from your post #1.
                                  Post each measurement.
                                  • Adogabriel100
                                    Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                    by Adogabriel100
                                    Hey! This is a A1278 macbook 2011.
                                    Problem: Not turning on / No green light
                                    Im using by3200s charger.
                                    Voltajes:
                                    PPBUS_G3H = 12.26v
                                    SMC_RESET_L = 3.3v
                                    PP3V42_G3H = 3.42v
                                    U7000 =
                                    Pin 1 CHGR_AGATE = 0v
                                    Pin 2 CHRG_DCIN = 19v
                                    Pin 3 CHRG_ACIN = 4.6v
                                    Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                    Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                    Pin 12 PP3V42_G3H = 3.42v
                                    Pin 13 CHRG_RST_L = 3.3V
                                    Pin 14 SMC_BC_ACOK = 0.8V
                                    Pin 19 PP5V1_CHRG_VDD = 5.05V
                                    Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                    04-01-2024, 01:02 PM
                                  • envym
                                    MacBook Pro 2018 with Activation Lock
                                    by envym
                                    Hi everyone!
                                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                    06-27-2025, 08:54 AM
                                  • salopian
                                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                    by salopian
                                    Hello. I would need some advice please.
                                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                    I have already replaced the logic board with another...
                                    02-27-2021, 07:30 AM
                                  • mferna14
                                    Apple MacBook A1398 820-00138-A missing 5V
                                    by mferna14
                                    HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
                                    01-16-2023, 01:35 PM
                                  • _Cupa
                                    MacBook Air 2011 13" >820-3023 A< no power (PLT_RESET_L missing)
                                    by _Cupa
                                    Dear community,
                                    this is my very first post, I am quite new to macbook repairs, and I am excited:-)
                                    I have a 2011 MacBook Air 13' that does not power on. No fan spin, nothing.
                                    Here are the specs:
                                    MacBook Air Mid-2011
                                    CPU: 1.7 GHz Core i5 (I5-2557M)
                                    Model: A1369 (EMC 2469)
                                    RAM: 4 GB
                                    VRAM: 384 MB
                                    The first question:
                                    Unfortunately, it came with a 'fake' power adapter which seems not to talk to the computer. Sometimes it does show green light immediately after connecting it to the board,...
                                    04-01-2021, 02:01 PM
