Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    I need help with Macbook A1989. It stuck at 5V / 5mA.
    I already do some measurements https://logi.wiki/index.php/CD3215_Bootup_Sequence
    PP20V_USBC_XB_VBUS - 5V
    PP3V3_UPC_XB_LDO - 3V
    PP1V8_UPC_XB_LDOA - 1.8V
    PP1V8_UPC_XB_LDOD -1.8V
    PP1V1_UPC_XB_LDO_BMC - 0V
    It's the same on all CD3215. There is no signs of corrosion or something like that.
    What should I check?
    Thanks for help.
    Martin
  • mon2
    • Dec 2019
    • 14662
    Re: Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
    Flip the power adapter cable by 180 degrees and test each USB -C port.
    Need to have a voltage on:
    for the USB -C port being used to power the logic board.
    This is the power rail this is used to communicate with the power adapter for the power delivery contracts over the CCx pins.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      Thanks for reply.
      Already checked all ports. It's all the same. There is no voltage on
      Checked all 4 CD3215 chips. Same problem on all of them.
      • mon2
        • Dec 2019
        • 14662
        Remove all power. Meter in diode mode.
        Red meter probe, yes red, to ground.
        Black meter probe to the pin to test.
        Measure the same BMC power LDO rails as above to check if there is a short on the rail.
        Post each measurement.
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          ub400
          0.525
          u3200
          0.525
          ub300
          0.538
          u3100
          0.538
          • mon2
            • Dec 2019
            • 14662
            These are good readings and each is without a short on the rail.
            What is the voltage to ground reading of PPBUS_G3H @ F7000 ?
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              It's shorted.
              • mon2
                • Dec 2019
                • 14662
                Ok. Remove the fuse @ F7000. Then check again to see if PPBUS_G3H is available on F7000, pin # 1 (ISL = producer side).
                Then remove all power -> meter in resistance mode. Measure the resistance to ground of F7000, pin # 2.
                What is the resistance ? Do not do any voltage injection till we know more about the case. A high side mosfet short can kill the CPU / PCH.
                • martyjelen
                  • Mar 2023
                  • 127
                  • Czech republic
                  Fuse is now removed.
                  There is a 12.26V on pin # 1
                  There is 0.2 Ω on pin # 2
                  • mon2
                    • Dec 2019
                    • 14662
                    Would you have an adjustable power supply?
                    That can support 1 volt output?
                    Need to check one more section to be sure the CPU high side mosfet is not leaky. Then can inject 1 volt max onto the downside of the F7000 fuse pad. This will cause the shorted part to heat up and show it's face.
                    • martyjelen
                      • Mar 2023
                      • 127
                      • Czech republic
                      Yes, I have adjustable power supply. But I never done this before. Is it possible to do this without thermal camera?
                      • mon2
                        • Dec 2019
                        • 14662
                        Yes it is.
                        With such a hard short, the component will heat up and crack under the pressure. You should be able to smell it. A simple trick is to pour the region with caps with IPA (pharmacy grade alcohol) and watch it mist from the heating action of the shorted part. We did this for a while.
                        Now we use the short killer product rated @ 30A. We dial up 0v8 (must be 1v or under to be safe) and apply this zapper. Often, the ceramic or tantalum cap that is shorted will crumble into pieces with this process.
                        See attached.
                        Remove all power. Meter in resistance mode.
                        One meter probe at F7000, pin # 2 (downstream = consumer side of this rail)
                        Other meter probe @ L7210, pin # 2.
                        We are checking if the high voltage rail created by the ISL (PPBUS_G3H) is shorted internally through high side mosfets inside the CPU power rails.
                        If yes, then likely the CPU is toast from the same event.
                        Either way, you can inject 1 volts onto the PPBUS_G3H and check the current of your power supply and watch for the component (likely a capacitor) to heat up and crumble.
                        For now, share the resistance reading of the above.
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          It is about 5Ω.
                          • mon2
                            • Dec 2019
                            • 14662
                            To confirm, you are reading a 5 ohm resistance between PPBUS_G3H and the inductor / coil referenced in my last post?
                            That is bad news. This means that the high side mosfet inside the switch regulator is shorted and very likely passed the high voltage from this rail onto the CPU / PCH and killed it.
                            Do wait on others to comment but the CPU will have to be replaced which is not a simple process.
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              Assuming no direct short PPBUS_G3H → PPVCC_S0_CPU:
                              resistance PPBUS_G3H→GND = 0 ohm
                              resistance GND→PPVCC_S0_CPU = 5 ohms
                              resistance PPBUS_G3H → PPVCC_S0_CPU = resistance PPBUS_G3H→GND + resistance GND→PPVCC_S0_CPU = 5 ohms
                              If direct short PPBUS_G3H→PPVCC_S0_CPU and no direct short PPBUS_G3H→GND:
                              resistance PPBUS_G3H→PPVCC_S0_CPU = 0 ohm
                              resistance PPVCC_S0_CPU→GND = 5 ohms
                              resistance PPBUS_G3H→GND = PPBUS_G3H→PPVCC_S0_CPU + resistance PPVCC_S0_CPU→GND = 5 ohms
                              • mon2
                                • Dec 2019
                                • 14662
                                Excellent. Thanks @Piernov.
                                Let us continue...
                                Remove all power -> meter in resistance mode -> check the resistance to ground of L7210, pin # 2.
                                What is the measurement?
                                How current can your power supply support?
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  Thank you very much guys I really appreciate your help. I will reply tomorrow.
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    So, I checked it again.
                                    F7000, pin # 2 > L7210, pin # 2 - 5Ω
                                    L7210, pin # 2 > GND - 5Ω
                                    Current limit of my power supply is 5A.
                                    • mon2
                                      • Dec 2019
                                      • 14662
                                      Dial up 1 volt on your power supply.
                                      Mate the red probe of your power supply to F7000, pin #2 pcb pad. Black probe to ground.
                                      Do not have any other power to the logic board.
                                      This setup will inject 1 volt onto the shorted component on the logic board and will cause that part to heat up quickly. Note which part heats up. Often will be a defective capacitor which will often crack open. Then turn off this dc power supply and check the resistance to ground again at F7000, pin #2.
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        Ok, thanks. And how much amps?
                                        • MyronViegas
                                          MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                                          by MyronViegas
                                          Hey guys,
                                          I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                                          Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                                          10-06-2025, 08:45 AM
                                        • PITERPENY
                                          MacBook A1989. Stuck in DFU and won't turn on!
                                          by PITERPENY
                                          MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                                          20 volts and 0.00 amperes
                                          Does anyone have any suggestions?
                                          It's possible that the problem is in the EFI (BIOS),
                                          who has the EFI ROM file please share
                                          01-11-2024, 07:43 PM
                                        • nosinformatica
                                          Macbook Pro 13'' - A1989 stuck at 5v
                                          by nosinformatica
                                          Preface : My primary job it's not repairing logic board, so please excuse me.
                                          The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                                          I'have read that these mac have two CD3125 in daisy chain.
                                          How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                                          09-29-2023, 06:29 AM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • modtool
                                          Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                                          by modtool
                                          Dear friends,
                                          a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                                          I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                                          I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                                          Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                                          10-25-2025, 05:09 AM
