Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
  • mon2
    • Dec 2019
    • 14175
    Re: Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
    Leave at 5A. We want the shorted part to heat up.
    For safety, keep the voltage at 1v or even 0v8.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      I didn't noticed anything heat up. There is still short.
      • mon2
        • Dec 2019
        • 14175
        When the power supply at 1v is applied, what is the current draw?
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          2 ampers
          • mon2
            • Dec 2019
            • 14175
            Confirm if the power supply is being current limited. If yes, increase this value to 5A and test again.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #26
              It's not. I set it to 5A. Still get only 2A.
              • mon2
                • Dec 2019
                • 14175
                Increase the voltage to 2 volts and test again. Monitor who is heating up.
                • martyjelen
                  • Mar 2023
                  • 127
                  • Czech republic
                  #28
                  I found it. It's C6555 and C6556. They are very hot.
                  • mon2
                    • Dec 2019
                    • 14175
                    Excellent!! Flux and remove both of these parts.
                    Be sure the pads are not shorting and then check the resistance to ground again if F7000, pin #2.
                    • martyjelen
                      • Mar 2023
                      • 127
                      • Czech republic
                      #30
                      I already removed C6555 and there is no short anymore. I can measure F7000, but I will do it on Monday. I must go out. I will reply on Monday.
                      Thanks again. You are very kind.
                      • mon2
                        • Dec 2019
                        • 14175
                        Excellent! Place back the removed fuse and test it all again.
                        Thanks to @Piernov for the clarity on how to test the short condition - initially to me, thought your CPU was shorted.
                        This is a good read as well:
                        https://logi.wiki/index.php/PPBus_G3H
                        Review the article on PPBus Shorts (@Piernov).
                        Will cross my fingers waiting for some good news on Monday.
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          #32
                          Just to be sure, you mean place the fuse back, connect it to power supply trough USB-C and see If I get 20V?
                          Sorry for dumb questions, but I'm really a newbie. And I don't want to kill the board completely.
                          • mon2
                            • Dec 2019
                            • 14175
                            Yes. Remove all power to the board. Start with posting the resistance to ground of the F7000, pin #2 so we can be sure the short is gone. Then solder back the removed fuse and confirm the voltage of PPBUS_G3H.
                            Ideally, this was the only root cause and the unit should be repaired.
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              #34
                              It's about 5MΩ.
                              • mon2
                                • Dec 2019
                                • 14175
                                Good resistance. Solder back the fuse and test again.
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  #36
                                  Now I get 20V on all ports. You are the best! Thank you very much!!!
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    #37
                                    Sadly, when I put PCB back it still won't turn on. Maybe there is another problem.
                                    • mon2
                                      • Dec 2019
                                      • 14175
                                      What is the voltage and current draw? Is the current draw stable or cycling?
                                      What is the voltage to ground reading of PPBUS_G3H @ F7000 ?
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        #39
                                        20V / 0.436A - stable
                                        Voltage at F7000 PPBUS_G3H is 12.5V. I noticed that U7800 is hot.
                                        • mon2
                                          • Dec 2019
                                          • 14175
                                          What is the voltage to ground of ALL_SYS_PWRGD_R ?
                                          Perhaps try DFU.
                                          • PITERPENY
                                            MacBook A1989. Stuck in DFU and won't turn on!
                                            by PITERPENY
                                            MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                                            20 volts and 0.00 amperes
                                            Does anyone have any suggestions?
                                            It's possible that the problem is in the EFI (BIOS),
                                            who has the EFI ROM file please share
                                            01-11-2024, 07:43 PM
                                          • nosinformatica
                                            Macbook Pro 13'' - A1989 stuck at 5v
                                            by nosinformatica
                                            Preface : My primary job it's not repairing logic board, so please excuse me.
                                            The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                                            I'have read that these mac have two CD3125 in daisy chain.
                                            How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                                            09-29-2023, 06:29 AM
                                          • Bmet
                                            MacBook Pro 13 inch A2238 M2 stuck on 5V
                                            by Bmet
                                            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                            04-02-2025, 05:02 PM
                                          • Steven Pieter
                                            Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                            by Steven Pieter
                                            hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                            11-24-2024, 10:02 AM
                                          • ErinV
                                            MacBook Pro A1989 820-00850-A not powering on
                                            by ErinV
                                            Hey everyone!
                                            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                                            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                                            The diode voltages around all 4 CD3215's seem fine.
                                            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                                            09-30-2024, 10:21 PM
