820-01700-A macbook pro
  • kartal
    • May 2019
    • 28
    • turkey
    Hello. I have one 820-01700-A macbook pro. device was working battery changed Tested for 1 day no problem today when I turn on the device the keyboard + touchbar + speaker does not work, I reinstalled the software, but the result is the same. Headphones have sound but no sound out. the keyboard has backlight but the keyboard is not working the touchbar is not working. No liquid damage on the motherboard. R5103 1.8v available. keyboard J6701 socket 1 no standing 1.8v available. what missing voltage might have affected these 3 hardware?
  • mon2
    • Dec 2019
    • 14673
    Re: 820-01700-A macbook pro
    Issues after the battery change?
    Check the ESD diode linked to the smbus lines (SCL and SDA) on the battery connector.
    Carefully measure the voltage to ground of each pin of the battery connector. Post the pin # and each voltage.
    If either the SCL or SDA pins are low, the smbus interconnect is not working due to a damaged esd tvs diode from an ESD surge event. Then the ESD diode has to be removed / replaced.
    • kartal
      • May 2019
      • 28
      • turkey
      It was tested for 1 day after the battery was changed, everything was working, but after turning on the device today, these 3 hardware are not working.
      • kartal
        • May 2019
        • 28
        • turkey
        J6951
        1 - 0v
        2 - 1.7v
        3 - 1.7v
        4 - 0v
        5 - 0v
        6 - 0v
        U6950 diode has been changed but the same problem still persists.
        • mon2
          • Dec 2019
          • 14673
          The battery is dead?
          Review this thread and resolution:
          https://boards.rossmanngroup.com/thr...charger.61444/
          • kartal
            • May 2019
            • 28
            • turkey
            battery is new 2 tried but the result did not change the same 3 hardware unfortunately does not work.
            • mon2
              • Dec 2019
              • 14673
              On the new battery, is there a charge?
              Review the PPVBAT_G3H_CONN voltage to ground.
              Pin # 2 & 3 are linked to the I2C (SCL & SDA) lines and ~1v8 is correct.
              • kartal
                • May 2019
                • 28
                • turkey
                R5221 resistor shows 1 input 1.8v 2 no 1.7v. with the battery installed. the battery is charging, the device turns on, but still the keyboard + touchbar + speaker is not active. There is sound in the headphone output. these 3 hardware is not working .PPVBAT_G3H_CONN voltage 12v available.
                • mon2
                  • Dec 2019
                  • 14673
                  1v7 is ok since the clk line is pulsing high and low so the voltage is normal to show a bit lower.
                  • kartal
                    • May 2019
                    • 28
                    • turkey
                    so where could the problem be in 3 hardware disabled device.
                    • mon2
                      • Dec 2019
                      • 14673
                      Check your voltage to ground of
                      PP1V8_SLPS2R
                      P1V8G3S_EN
                      PP3V3_G3H_T
                      What are the measurements?
                      • ugamazing
                        • Jun 2013
                        • 171
                        • usa
                        Did you remove the board and trackpad before replacing the battery? Is the battery a genuine Apple battery or generic/third-party? Did you damage the battery data cable?
                        This sounds like physical damage to the board. Inspect closely. Make sure cables are not cracked/damaged.
                        • kartal
                          • May 2019
                          • 28
                          • turkey
                          PP1V8_SLPS2R
                          P1V8G3S_EN
                          PP3V3_G3H_T
                          now i can see both voltages are available. The device was brought to me from another service, the battery was changed, the battery is not the original apple, but it is a quality battery. It worked flawlessly for 1 day. After 1 day, when they turned on the device, the keyboard, touchbar and sound did not work. I have examined the motherboard a lot, there is no liquid contact or broken parts. voltages seem fine. The device is charging, it opens with both the cable and the battery. There is no problem in its operation, but these 3 hardware do not work. This is the first time I encounter such an error.
                          • kartal
                            • May 2019
                            • 28
                            • turkey
                            battery is not original apple but same quality battery. The device worked flawlessly for 1 day after the battery was changed. The next day, when they turned on the device, the keyboard + touchbar + speaker sound did not work. The device is charging, it works with both the adapter and the battery, but these 3 hardware do not have voltages, I can't see any problem, I can't see any physical problem. There is no broken piece on the motherboard. I tried with another battery, same result. This is the first time I have encountered such an error.
                            • modtool
                              Macbook Pro A1989 fallen, reboots if touchbar connected
                              by modtool
                              Hi to all,
                              the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                              Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                              11-10-2023, 07:42 AM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • computeka
                              Macbook Air A2337 820-02016-07 No sound problem
                              by computeka
                              How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
                              05-08-2024, 10:26 AM
                            • Comp_Pro
                              Macbook Air 820-00165 Static Chime Sound
                              by Comp_Pro
                              Hello all,
                              I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                              11-02-2023, 03:23 PM
                            • tommy97
                              Apple MacBook A1707 No Audio/Sound
                              by tommy97
                              I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                              I've also replaced U6300, but the problem persists.
                              Here are the current voltage readings:
                              • PPV18_S0: 1.8V
                              • R6402: 1V
                              • R6405: 1V
                              • R6403: 1V
                              • AUD_SPKRAMP_RESET_L: 1.3V
                              • PPBUS: 12.6V
                              03-10-2025, 11:22 AM
