MSI GE62 6QF MS-16J41 not reacting to power button
  • questore
    • Dec 2015
    • 506
    • csongrád
    Hi Guys,
    This laptop came to me as a gift, and know nothing about it. I would like to fix it.
    When plugged in without battery nothing happens.
    If I plug the battery then connect the power supply, blue LED lits up in the front.
    After cleaning the DCIN mosfet area (black burn residue was present near the first 2 mosfet)
    + 3.3v is present on the power button and when pressed it goees 0v for a second, but no other reaction on the laptop.
    + Measured 5.1v some places
    + Board Taking 0.010mA when charger plugged in.
    + Flashed the BIOS from this forum with exact modell number (no change)
    Attaching a schematic - IC numbers are somehow different then my board (example: schematics U41 BIOS IC on my board is U43)
    Can you give me an idea where to go?
    Schematic: >>click here to download<< ---> https://www.badcaps.net/forum/showth...96#post1233196
    Last edited by Vesko356; 04-28-2023, 07:43 AM. Reason: Added MS-16J41 to the thread title. Attachment removed and replaced with link.
  • questore
    • Dec 2015
    • 506
    • csongrád
    Re: GE62 6QF not reacting to power button
    After looking carefully on the board with my microscope. I have noticed that 2 resistors seem to be miissing next to BIOS chip (BIOS IC was drowned in flux residue so assuming someone messed with it)
    Attached picture with red marks on the assumed missing resistors.
    Pin 3 and 7 should be connected to +VCCSPI trought 1KOhm resistors.
    Now they are 1MOhm and 10 MOhm measured. (Page 24 in schematic.)
    Someone Please confirm my action before proceeding with solder iron.
    • questore
      • Dec 2015
      • 506
      • csongrád
      Checked it on another working board and it also has nothing on that mark.
      Back to square 1.
      • questore
        • Dec 2015
        • 506
        • csongrád
        Done some more board cleaning, now 3vsus and 5vsus come alive when power button pressed. Going forward.
        • questore
          • Dec 2015
          • 506
          • csongrád
          Other schematic seemed to be not for this board altough the first page write ms-16j4. Attaching another that is correct.
          Following this docu I found out that SUSPWROK is present from the TPS51225CRUKR chip when power button pressed, but never arrives to the EC chip 109 pin.
          Tryed to follow the trace but it instantly disappears after the pin out and the KBC chip 109 pin comes from somewhere the bottom of the chip so I wont see anything. Tryed to discover the other side of the board but dont see any suspicious thing.
          NEXT STEP: solder a thin wire to SUSPWROK OUTPUT and solder OTHER SIDE it to the pin 109 of the KBC. Anyone disagrees?
          • piernov
            • Jan 2016
            • 4436
            • France
            MSI GE62 6QF is a Skylake platform. MS-16J4 is a Skylake platform, MS-16J2 is a Haswell platform, they use different ECs. In any case, the board model number should be written somewhere on the board.
            Additionally, please link to topics in the Schematic subsection rather than uploading schematics in your post here.
            • questore
              • Dec 2015
              • 506
              • csongrád
              Point there, I forgot to write the modell number, I was certain I did, but no. Thank you. I will also check the KBC number if it is correct with schematic.
              Modell number is: Ms-16j41
              • questore
                • Dec 2015
                • 506
                • csongrád
                Re: MSI GE62 6QF MS-16J41 not reacting to power button
                Since my board is ms-16j41 v1.0 it was hard to chase down because the schematic was Rev0A. but found that APL5930 is memory voltage regulator is presenting 1.2v on VOUT and NOT give out +2.5V_MEM_PWRGD signal.
                pins measured after powerbutton pressed:
                #1 GND - 0v
                #2 - FB - 0,81V
                #3 - VOUT - 1.21V
                #4 - VOUT - 1.21V
                #5 - VIN (3vsus) - 3.1V
                #6 - VIN (5vsus) - 5.12V
                #7 - POK - fluctuating 0-2v even when no powerbutton pressed
                #8 - DIMM_ON_2V5 (Enable) - 3.35v
                The schematic Page 41 shows a 4.99K resistor between VOUT and FB but I have measured 1.32KOhm (could it be because a different board revision)
                Should I replace the Regulator?
                • piernov
                  • Jan 2016
                  • 4436
                  • France
                  You are measuring +1.2VSUS not +2.5V_MEM.
                  • questore
                    • Dec 2015
                    • 506
                    • csongrád
                    Yes you are right, there is 2 chips of APL5930 and I have measured the other one.
                    But, does it need to be replaced? It seems faulty to me.
                    • piernov
                      • Jan 2016
                      • 4436
                      • France
                      Nothing looks wrong there.
                      • questore
                        • Dec 2015
                        • 506
                        • csongrád
                        Next, I have found the 2.5v IC.
                        pin 5 - 3V (+3vsus)
                        pin 6 - 5v (+5vsus )
                        No voltage on DIMM_ON_2V5 Enable signal (pin 8)
                        no output voltage on pin 3-4
                        also checked ENE9028 ic pin 16 but no 3.3v there either
                        In schematic I did not found any G3-S0 flow diagram so i don't know what to check next. Any idea?
                        • mon2
                          • Dec 2019
                          • 14267
                          Perhaps review the schematic for the ms-16j5 - available on Alisaler (free download). This board may be closer to your logic board.
                          • questore
                            • Dec 2015
                            • 506
                            • csongrád
                            On the MS16j2 schematic i found a power on sequence and found that these need to be present after start button pressed:
                            SUSPWROK - 3.5v
                            SUSPWRACK - 3.4V
                            AC_PRESENT should be high before DIMM_ON is enabled.
                            AC_PRESENT on my board is 0.4mV
                            • mon2
                              • Dec 2019
                              • 14267
                              Connect your power adapter.
                              Meter in DC volts (30v or higher scale).
                              Carefully measure the voltage to ground of each pin of PU2 charger IC.
                              Post the measurements and their pin number.
                              • questore
                                • Dec 2015
                                • 506
                                • csongrád
                                I also suspected the Charger chip and I remember that it has 0.3mV on the AC_OK line, but I make measurments and post them.
                                • questore
                                  • Dec 2015
                                  • 506
                                  • csongrád
                                  BQ24737 With only AC plugged in NO BATTERY
                                  pins:
                                  1 - 19,9 v (ACN)
                                  2 - 19,9 v (ACP)
                                  3 - 0,5 mv (CMPOUT)
                                  4 - 0,22 v (CMPIN)
                                  5 - 10 mv (ACOK)
                                  6 - 2,7 v (ACDET)
                                  7 - 1 mv (IOUT)
                                  8 - 3,3 v (SDA)
                                  9 - 3,3 v (SCL)
                                  10 - 1,14 v (ILIM)
                                  11 - 3,3 v (BM#)
                                  12 - 3,6 v (SRN)
                                  13 - 3,65 v (SRP)
                                  14 - 0 v (GND)
                                  15 - 0 v (LODRV)
                                  16 - 6,1 v (REGN)
                                  17 - 6 v (BTST)
                                  18 - 3,7 v (HIDRV)
                                  19 - 3,7 v (PHASE)
                                  20 - 19,6 v (VCC)
                                  • questore
                                    • Dec 2015
                                    • 506
                                    • csongrád
                                    When only battery connected the ACOK signal goes 3.31V so It looks good!
                                    What to check next?
                                    • mon2
                                      • Dec 2019
                                      • 14267
                                      ACOK# is an active low signal so if this line is low = 0 volts, then the external adapter is OK. With only the battery, your reading is ok since the external adapter is missing.
                                      Measure the voltage to ground of each coil (inductor) on the logic board.
                                      Do you see the blue light on the board light up with the adapter & battery connected? Not sure what the blue light denotes but check the power rails (each inductor is a power rail).
                                      Do you still have a known good board to compare against?
                                      • questore
                                        • Dec 2015
                                        • 506
                                        • csongrád
                                        Yes when AC & BATTERY are both connected, there is a blue Led lit up.
                                        All coils are ok, lowest is CPU 3.2ohm
                                        According to the ms-16j2 g3->s0 sequence, (I have linked it before) everything is good until SUSCLK and AC_PRESENT signal. Should I check 32khz?
                                        • themosttogain
                                          HP Envy 13-BA1565na with intermittent power button
                                          by themosttogain
                                          Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                          07-12-2024, 03:03 AM
                                        • questore
                                          la-h482p rev 1.0 not reacting to power button
                                          by questore
                                          Hi Everyone,
                                          I have a la-h482p rev 1.0 on my desk that is not reacting to power button.
                                          + Every ALW a LO are present when battery is plugged (11.7V)
                                          + Charger shows charging led orange when charging and white LED when done charging.
                                          + EC_ON also high 3.1V
                                          + power button has 3v and goes down to 0 when pressed.
                                          + BIOS does not have 3v on the 8th pin (+3V_SPI never rises only 0.07milivolt risen after battery plugged)
                                          + PCH hase 1.5V on one capacitor on top nothing on the others
                                          + nothing gets hot only SIO and 3V/5V regulators are 22 C
                                          04-08-2025, 02:11 AM
                                        • TimeRabbit07
                                          Asus FX517ZC charges but power button does nothing
                                          by TimeRabbit07
                                          Hi all!
                                          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                                          Here are its various numbers and identifiers:
                                          Model short: FX517Z
                                          Model long: FX517ZC-HN114W
                                          SN: NANRCX01S57842E
                                          CN: 3SDB 12M
                                          MFD: 2022-10
                                          Motherboard model: DA0NJLMBAE0 REV E
                                          Symptoms:
                                          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                                          History so far:
                                          The...
                                          09-04-2024, 05:48 PM
                                        • reessi
                                          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                          by reessi
                                          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                          No corrosion any where!
                                          Tried a replacement power button off ebay and the same.
                                          Very occasionally it will work with the power button connected!
                                          Same results with or without the battery.
                                          Can it be a fault with the Audio board or the mainboard?
                                          The touch Id assembly connects through the Audio board first then to the Mainboard.
                                          Flex...
                                          06-26-2024, 03:31 PM
