MSI GE62 6QF MS-16J41 not reacting to power button
  • questore
    • Dec 2015
    • 565
    • csongrád
    Re: MSI GE62 6QF MS-16J41 not reacting to power button
    I have bought the exact schematic.
    https://www.badcaps.net/forum/showpo...14&postcount=5
    Now I can go and measure everything.
    Next I will check BATLOW# signal to see if it is prevents the the PCH to go to S5->S4->S3->S0
    Now that I have an exact schematic I remeasured some places:
    + AC_PRESENT - 3.4V
    + BATLOW# is 3.35V so something is wrong with the powers. I guess I remesure everything on VSUS and always on voltages.
    • questore
      • Dec 2015
      • 565
      • csongrád
      +3vsus seems to be intermittent.
      After pressing power button 3,4v appears for 4 seconds, then it disappears then comes back, then disappears again. Does this 2 times before board shuts off.
      TPS51225CRUKR PGOOD signal is stabil 3.36v all along.
      Any ideas?
      • questore
        • Dec 2015
        • 565
        • csongrád
        RTCVCC - 3.17
        INTRUDER#, 2,7
        RTCRST# 3.17v
        SRTCRST# 3.17v
        I found a broken resistor on R457 (45.3KR1%0402 )
        I will replace it but i dont know if this will solve the problem.
        • questore
          • Dec 2015
          • 565
          • csongrád
          Replaced, R457 and no change, BUT....
          I have discovered that SUSCLK is present but the board is missing the
          X_32.768KHZ 12.5p_S-RH-21 crystal. It makes sense that its not booting.
          I think I have one from a G551JM board .
          Are they interchangeble with any 32.768 crystal?
          • mon2
            • 14673
            These are common jellybean (clock crystal) parts. Just replace it and test it. It should be fine.
            • questore
              • Dec 2015
              • 565
              • csongrád
              #26
              Thanks, I be back after replacing it.
              • piernov
                • Jan 2016
                • 4439
                • France
                #27
                No stuff, SUSCLK derived from Y5.
                • questore
                  • Dec 2015
                  • 565
                  • csongrád
                  #28
                  Thanks, I go forward...
                  Any idea?
                  • mon2
                    • 14673
                    Look for a crystal Y5. Is it on the board?
                    • questore
                      • Dec 2015
                      • 565
                      • csongrád
                      #30
                      Yes but not seeing any voltage on any side. (Y2 missing has 3.3 in the incoming line)
                      Also measured some sequence points:
                      RTCVCC - 3,1V
                      RTCRST - 3,1v
                      PWR_SRC - 19,7V
                      +3VALW - 3,31V
                      +5VALW - 5,02V
                      PWR_SW# - 3,31V (WHEN power button pressed, it goes to 0v for second, then rises back to 3.31v)
                      SUS_ON - 3,30V after pressing power button
                      +3VSUS - 3,39V after pressing power button (NOT FLUCTUATING)
                      +5VSUS - 5,14V after pressing power button (NOT FLUCTUATING)
                      SUSPWROK - 3,34V after pressing power button
                      RSMRST# - 3,30V after pressing power button
                      SUSPWRACK - 0,55V BEFORE Pressing power button. goes down to 0.44V until power button is held.
                      SUSCLK - 3,39V
                      AC_PRESENT - 3,39V
                      PM_PWRBTN# - 3,31V
                      PM_SLP_S5 - 0V
                      PM_SLP_S4 - 0V (when accidentaly shorted to 3.3v then it goes up to 3.3v and holds it (power button blue led begins to blink slowly))
                      PM_SLP_S3 - 0V
                      • questore
                        • Dec 2015
                        • 565
                        • csongrád
                        #31
                        More measurements:
                        Y5 both pin is OL resistance to ground!
                        Y2 (pin #1 is 649Kohm , Pin #2 is OL)
                        • questore
                          • Dec 2015
                          • 565
                          • csongrád
                          #32
                          SLP_SUS is also OL to ground all the time!
                          Where to go next?
                          • questore
                            • Dec 2015
                            • 565
                            • csongrád
                            #33
                            Also noticed that someone removed the PCH glue from the corners so it is probably messed with.
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 501
                              • somewhere in europe
                              #34
                              have had a similar problem with an asus gaming board. pch/soc was dead...
                              • questore
                                • Dec 2015
                                • 565
                                • csongrád
                                #35
                                Should I try to reheat the PCH to be sure it is not just a cracked Solder joint, or should I take it right away to a local repair shop and replace PCH instead?
                                • questore
                                  • Dec 2015
                                  • 565
                                  • csongrád
                                  #36
                                  Digging Further into the problem I found intel documentation about the chipset here:
                                  https://manualzz.com/doc/o/knhf9/int...address-ranges
                                  It seems all the floating pins are in one quarter of the PCH (Top View – Lower Right) Page 92
                                  Maybe it is worth a careful reheat. Anyone has other idea?
                                  • questore
                                    • Dec 2015
                                    • 565
                                    • csongrád
                                    #37
                                    I really dont want to reheat the PCH if not necessary.
                                    I'm out of my knowledge here but I want to learn what could be causing this.
                                    Top of the PCH I have measured 43Ohms to ground. I read some forums and it seems normal. Nothing is shorted.
                                    I have made a Clean ME BIOS and reflashed it but nothing changed.
                                    So my idea is that I introduce a 32k crystal in the missing Y2 position where I have 3.3v. It can't hurt can it? If anyone has other idea or can explain what canI do please dont hesitate to write a comment.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #38
                                      I dont see EC_RST#/LID#/EC_PCH_PWROK/EC_ALLSYSPG in your measurements. What's the status with these pins on SIO?
                                      • questore
                                        • Dec 2015
                                        • 565
                                        • csongrád
                                        #39
                                        - EC_PCH_PWROK (KBC Pin 32) - 0V
                                        - EC_RST (KBC Pin 37, after R423) - 3,31V
                                        - LID# (KBC Pin 53) - 3,39V
                                        - EC_ALLSYSPG (KBC Pin 115) - 0V
                                        • mon2
                                          • 14673
                                          So issues with first and last voltages at this time.
                                          Check the power rails.
                                          • themosttogain
                                            HP Envy 13-BA1565na with intermittent power button
                                            by themosttogain
                                            Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                            I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                            Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                            07-12-2024, 03:03 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • questore
                                            la-h482p rev 1.0 not reacting to power button
                                            by questore
                                            Hi Everyone,
                                            I have a la-h482p rev 1.0 on my desk that is not reacting to power button.
                                            + Every ALW a LO are present when battery is plugged (11.7V)
                                            + Charger shows charging led orange when charging and white LED when done charging.
                                            + EC_ON also high 3.1V
                                            + power button has 3v and goes down to 0 when pressed.
                                            + BIOS does not have 3v on the 8th pin (+3V_SPI never rises only 0.07milivolt risen after battery plugged)
                                            + PCH hase 1.5V on one capacitor on top nothing on the others
                                            + nothing gets hot only SIO and 3V/5V regulators are 22 C
                                            04-08-2025, 02:11 AM
                                          • TimeRabbit07
                                            Asus FX517ZC charges but power button does nothing
                                            by TimeRabbit07
                                            Hi all!
                                            I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                                            Here are its various numbers and identifiers:
                                            Model short: FX517Z
                                            Model long: FX517ZC-HN114W
                                            SN: NANRCX01S57842E
                                            CN: 3SDB 12M
                                            MFD: 2022-10
                                            Motherboard model: DA0NJLMBAE0 REV E
                                            Symptoms:
                                            The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                                            History so far:
                                            The...
                                            09-04-2024, 05:48 PM
                                          • reessi
                                            Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                            by reessi
                                            With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                            No corrosion any where!
                                            Tried a replacement power button off ebay and the same.
                                            Very occasionally it will work with the power button connected!
                                            Same results with or without the battery.
                                            Can it be a fault with the Audio board or the mainboard?
                                            The touch Id assembly connects through the Audio board first then to the Mainboard.
                                            Flex...
                                            06-26-2024, 03:31 PM
