A2337 - 820-02016-a macbook air m1
  • sikocan
    • Oct 2019
    • 344
    BOARD: A2337 - 820-02016-A MACBOOK AIR M1
    Does not get recognised in Apple Configurator app.
    No physical damage such as liquid, corrosion or burns.
    User mentions of shutting down whilst in use.
    When charger installed without battery or any other connections, 20.336V / 0.05amps
    PPBUS_AON 12.016
    PPDCIN_AONSW - FF201/FF200 on both sides.
    PP5V_S2 5.183
    CHGR_PHASE1 11.18
    P3V8AON_SW3 3.793
    P3V8AON_SW2 3.796
    P3V8AON_VSW1 3.797
    PPVDD_CPU_SRAM_AWAKE 0.965
    PPVDD_ECPU_AWAKE 0.886
    PPVDD_PCPU_AWAKE 0.569
    BUCK1_LX4 0 (PPVDD_GPU_AWAKE)
    BUCK1_LX2 0 (PPVDD_GPU_AWAKE)
    BUCK8_LX0 0.73 (PPVDD_DISP_S1)
    BUCK9_LX0 0.811 (PPVDD_DCS_S1)
    BUCK3_LX0 1.797 (PP1V8_S2)
    PP0V6_S1_VDDQL 0.601
    PP1V06_S2SW_DRAM 1.064
    PP1V25_S2 1.224
    PP0V88_S1 0.878
    PP2V5_AWAKE_NAND 2.684
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • mkdj
    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
    by mkdj
    About me, my goal and the equipment I (don't) have:
    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
    About my issue and my goal:
    A friend of mine has a MacBook Air M1 A2337 that does not...
    04-03-2025, 08:28 AM
  • Adogabriel100
    where to get trusted CD3217. Problem with A2337 Macbook Air
    by Adogabriel100
    Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
    The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
    09-06-2024, 12:06 PM
  • Skrndelj
    Apple Macbook Air M1 A2337 Trackpad problem
    by Skrndelj
    Hello all,
    I am repairing a Macbook A2337 and i have a problem
    The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
    When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
    I inspected the whole board and everything seems fine.
    Can anyone help me as i didn't fiddle with trackpad...
    06-11-2024, 04:26 AM
  • Patrick501
    Macbook Air A2337 dead at 5V/0,00A
    by Patrick501
    Hey,
    I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
    USB Tester: 5V / 0,00A
    PPBUS_AON: 12,3 V
    PP5v_S2: 0 V no short
    PP3v3_S2_UPC: 0 V no short
    PP1v25_S2: 0 V no short
    PPDCIN_AON_CHGR_R: 5 V
    no enable signals for the S2 rails by the U8100
    both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
    PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
    PP1v5_UPC0_LDO_CORE:...
    11-29-2024, 02:47 PM
