iPod 6, replaced battery, now blinking apple
  • survivalbloke
    • Aug 2021
    • 309
    nevermind, bad battery connections.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    09-14-2023, 11:10 PM
  • ktmmotocross
    Apple A1990 and A1707 after battery change low speed
    by ktmmotocross
    Hello. H
    Have this apple A1990 and A1707 that goe slow after battery change. with old battery back it is normal. So battery is problem as it is aftermarket. what battery vendor except original can u recommend. so it work as it should...
    08-27-2025, 10:19 AM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • Norrecito
    iPod nano G3 - alternative soldering point for the white battery wire
    by Norrecito
    A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
    The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
    This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
    09-07-2024, 03:54 AM
