Is the GPU shorted? I think yes. What do you think?
  • sikocan
    • Oct 2019
    • 344
    GPU: N18E-G2-A1
    Board: GA-RP65X9
    Model: GIGABYTE AERO15 X9-9RT5 I9-8950Hk RTX-2070
    History: Lines on the bottom of the screen as pictured.
    Tech replaces LCD with the battery and power removed, same exact model screen.
    Laptop will not charge or turn on any longer.
    GPU side resistance is 0.096 Ohms with MESR-100 ESR Meter with the probes zeroed.
    Thank you, any input is appreciated.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Re: Is the GPU shorted? I think yes. What do you think?
    inject 1V 10A, with IPA on chip and u will be sure if u see a spot.
    • sikocan
      • Oct 2019
      • 344
      I've injected 0.9V at 2Amps - controlled. GPU did get slowly the longer I held it under thermal camera. Not doing 10amps
      This is the temp attached.
      • sikocan
        • Oct 2019
        • 344
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3622
          • slovakia
          dont know if it is enought W to show heatspot. gpu is using 80-100W normaly
          • sikocan
            • Oct 2019
            • 344
            Posted image.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3622
              • slovakia
              if u heat it slowly u miss the heatspot
              • sikocan
                • Oct 2019
                • 344
                So you mean if I come with high amp quickly, if it's something apart from GPU sorted, it'll glow first? I can try now
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 499
                  • somewhere in europe
                  "heat spot" doesn't always work, but it's a nice technique. and yes, go with high amps
                  • sikocan
                    • Oct 2019
                    • 344
                    I think this is good, GPU is fine I think.
                    • sikocan
                      • Oct 2019
                      • 344
                      NVVDD
                      NVIDIA GPU POWER source of injection.
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 499
                        NVVDD
                        post some measurments then. did you try to start the board "naked" with external monitor?
                        • sikocan
                          • Oct 2019
                          • 344
                          Board will not receive power after first MOSFET due to bqchip not allowing it.
                          • sikocan
                            • Oct 2019
                            • 344
                            I can't do high amps, at 0.9 it's limiting to 2amps with short killer and I will not go further.
                            • sikocan
                              • Oct 2019
                              • 344
                              Short killer values
                              • sikocan
                                • Oct 2019
                                • 344
                                I'll post more measurements tomorrow, even 19v at Shant resistor will not take any current with GPU coils back and battery connected to see if it'll charge battery, battery also refusing to work due to a short in system somewhere, I still suspect GPU. Let's see.
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  2.2. Don't suspect that something is shorted with no reason
                                  Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
                                  Also ESR meter != milliohm meter
                                  • sikocan
                                    • Oct 2019
                                    • 344
                                    Sorry to waste your time guys, at least I learned that such GPU resistance are normal, that's incredible. The PCH was shorted. After going through all coils and power rails as reported below for future repairers, the 3.3VA resistance was 16 ohms. How obvious. Schematics available on ZinZhiZao.
                                    Video showing the short: https://www.youtube.com/watch?v=jT8jLyJyg8U
                                    Here are readings for the future:
                                    Charger Voltage before plugging in: 19.463V
                                    +VAC_IN 19.463V
                                    CHQ1 - CSD17559Q5 N-CHANNEL MOSFET
                                    SOURCE 19.463V
                                    GATE 0.290
                                    DRAIN 0.372
                                    CHR41 - SHANT RESISTOR 1.245V
                                    CHL1 - +VBAT1 1.251
                                    PWR_BTN1 0V
                                    RESISTANCE VALUES - CABLES ZEROED USING BENCHTOP MULTIMETER
                                    COILS:
                                    FBVDDQ - NVPL5 - 18.8
                                    FBVDDQ - NVPL6 - - 18.8
                                    +V3.3A_EDP - L12 - OL
                                    VX_R - NVUSBL5 - 205
                                    LA_LX - LAL1 - 379
                                    +V5A_TBT3 - L8 - OL
                                    +VBAT1 - CHL1 - OL
                                    +V5A_MPS - SL1 - OL
                                    +V1.0A - V1L1 - 31.30
                                    NVVDD - NVPL4,3,2,1 - 0.25
                                    +VDDQ - ML1 - 35.6
                                    ** CONCERN ** +V3.3A_DSW - 3L1 - 17.30
                                    PS_USBC_PD_SW1 - NVUSB_L1 - OL
                                    +VCCIO - IOL1 - 43.5
                                    +VCCGT - IL5 - 7.6
                                    +VCCCORE - IL1,IL2,IL7, - 3.7
                                    +VCCSA - IL6 - 16.7
                                    SUPER IO OHMS - IT8587E/FX
                                    PIN 128 - +V3.3A_EC - 699 OHMS
                                    BIOS CHIP PINS OHMS -
                                    1 OL
                                    2 688
                                    3 745
                                    5 748
                                    6 766
                                    7 OL
                                    8 +V3.3A_SP VCC **CONCERN** 16
                                    • reessi
                                      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                      by reessi
                                      Hello:
                                      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                      I started on the ACER:
                                      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                      10-29-2024, 11:31 AM
                                    • Yanleb
                                      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                      by Yanleb
                                      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                      D608, good
                                      D618 RF101L4S, good (See warning 1 below)
                                      D619 RF101L4S, good (See warning 1 below)
                                      D865 RF101L4S, shorted (See warning 1 below)
                                      IC464 Inverter HA MC74HC1G14, shorted...
                                      03-09-2020, 12:00 AM
                                    • modtool
                                      HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                      by modtool
                                      Hi to all,
                                      the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                      I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                      I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                      04-01-2025, 08:22 AM
                                    • BalkanBoy
                                      Dead Razer Blade 14 2022, shorted CPU?
                                      by BalkanBoy
                                      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                      I removed coil and injected 0.7V, it draw around...
                                      09-27-2024, 12:44 PM
                                    • barry101
                                      Apple 820-3662 VCore shorted to ground.
                                      by barry101
                                      Hi, Would appreciate some help.
                                      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                      Get charger light but no fan spin or chime. No liquid damage.
                                      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                      06-24-2025, 07:34 AM
