Macbook Pro 13" M1 Reboots every 30 seconds
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    I wonder if anyone can assist. I have a macbook pro 13" M1 that had some liquid spilled on it. I have taken everything apart and cleaned with Isopryl and now the machine turns on but after about 30 seconds it will just shut off and start again. There is generally a pink screen that flashes just before it reboots.
    Anyone perhaps have any suggestions on what i can test or might need to replace?
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • modtool
    Macbook Pro A1989 fallen, reboots if touchbar connected
    by modtool
    Hi to all,
    the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
    Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
    11-10-2023, 07:42 AM
  • AlexVG
    Macbook A1466 820-00165 resets every 10 seconds
    by AlexVG
    It have had a problem with U7100 and short circuit in Q7130.
    I replaced them.
    It starts now and waiting 20 seconds and then starts to reset PM_SLP_S4_L every 10 seconds.
    Almost all voltages rising
    except U3090 and U3210 (LED) - not receives enable signal.
    U4500 is trying to rise - receives enable only 2-3 seconds
    Here is my measuring of important signals.
    What else could be the problem?
    I need to help.
    Thank you an advance....
    11-09-2023, 07:19 AM
  • MullySculder
    A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
    by MullySculder
    Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
    This was given to me by a friend who told me I could have it, if I fixed it.
    I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
    07-10-2024, 02:17 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
