A1990 820-01814 P5V_G3S missing
  • sese2504
    • Jan 2023
    Hello Guys
    My MacBook Pro a1990 820-01814 has no power
    It takes 20v and around 0.06A but it's cycling to 0A
    All 5v rails are missing
    P5VG3S_en_r , P3V3G3H_EN , P5V_3V3G3H_en are also missing
    The PMU is getting 3.3v but it doesn't output PMU_PVDDMAIN_EN which is responsible for these enable voltages above.
    Any Tipps?
    Thank you
  • sese2504
    • Jan 2023
    Re: A1990 820-01814 P5V_G3S missing
    I measured the SSD Voltages
    PP2V5_NAND_SSD0 is 0V
    All the other SSD voltages are also 0V but no short
    Any Advise?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Sounds like a bad T2. I believe mine had the same issues and it pointed to a faulty T2 chip.
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • sese2504
        • Jan 2023
        This is a answer I expected but don’t want to hear:/
        DFU is working but it can’t complete the recovery (ssd no voltage)
        Is there anything I could check maybe the i2C bus?
        • mon2
          • 14672
          if you suspect the I2C / SMBUS lines, remove all power.
          Meter in DIODE mode.
          Red meter probe, yes RED to ground.
          Black meter probe to the SCL line of the I2C / SMBUS interface.
          What is the voltage reading ?
          Repeat to test the SDA line of the I2C / SMBUS interface.
          Post each measurement.
          • geiti94
            Macbook Pro A1990 PP5V_G3S missing
            by geiti94
            Hello to all
            I have a macbook pro A1990 820-01814 that dont turn on
            PP5V_G3S and PP2V5_NAND_SSD0 are at 0V instead of 5V and 2.5V
            Someone have a sugestion where t start for find the problem?
            i cant set the unit in dfu mode
            12-15-2024, 10:59 PM
          • shlomim412
            a1990 820-01814 liquid damage - missing s5 rails
            by shlomim412
            Hello
            having issues with a1990 820-01814 logicboard
            was stuck on 5v
            liquid damaged on U9080 area
            replaced u9080 and cleaned underneath, also replaced c9080 which was corroded.
            after that was drawing 20v with low amperage (0.06-0.08)
            after removing the heatsink i found alot of corossion on U7370 area and U9850
            i replaced U9850 and reflow U7370 and surrounding caps \ resistors..
            now still getting 20v 0.08-0.05.
            i found out missing pp3v3_s5 and pp1v8_s5
            assembled the...
            04-29-2023, 03:57 PM
          • ugamazing
            820-02020 PPBUS_AON missing
            by ugamazing
            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
            02-05-2025, 04:21 PM
          • jpreza
            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
            by jpreza
            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
            Looking at the card, it appears to be missing the following:
            1x 1.0uH inductor - orange square
            2x...
            11-01-2024, 10:54 PM
          • gurj1979
            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
            by gurj1979
            Hey guys.
            Need help with this one.
            Fan not spinning due to missing PWN Fan signal.
            Also 5 seconds from powering up it freezes, unless in BIOS.
            But as soon as Windows starts to load, it will freeze.
            CPU is COLD / Room temp when it freezes.
            I've replaced the CPU, same problem.
            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
            Replaced fan - same problem.
            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
            08-19-2024, 05:22 PM
