a1990 820-01814 liquid damage - missing s5 rails
  • shlomim412
    • May 2018
    • 45
    • israel
    Hello
    having issues with a1990 820-01814 logicboard
    was stuck on 5v
    liquid damaged on U9080 area
    replaced u9080 and cleaned underneath, also replaced c9080 which was corroded.
    after that was drawing 20v with low amperage (0.06-0.08)
    after removing the heatsink i found alot of corossion on U7370 area and U9850
    i replaced U9850 and reflow U7370 and surrounding caps \ resistors..
    now still getting 20v 0.08-0.05.
    i found out missing pp3v3_s5 and pp1v8_s5
    assembled the mac, trackpad is clicking but no image, the machine DOES goes into dfu but fail to restore\revive with error -
    AMRestoreErrorDomain – 0x6 (6)
    any ideas?
    i have a good board to compare measuring to but not sure where to begin...
    any help will be appreciated.
    thanks..
  • mon2
    • 14657
    Re: a1990 820-01814 liquid damage - missing s5 rails
    Hi. It is fauda
    Yours may be the last case here:
    https://repair.wiki/w/A1990_2018-201...ar_MacBook_Pro
    • shlomim412
      • May 2018
      • 45
      • israel
      Hello mon
      thanks for the quick answer
      will try to replace u3000, will have to order this one :|
      but in general - the error - AMRestoreErrorDomain – 0x6 (6)
      means problem with the ssd?
      how can i determine if the ssd is ok or not on this board?
      • mon2
        • 14657
        Hi. The link was shared for a review to check if the fault is the same as yours. Do not replace the component till we have a confirmation the part is defective.
        Check with a thermal camera or even IPA over this part. If the alcohol evaporates quickly then the component is heating up.
        Check your SSD voltages.
        https://boards.rossmanngroup.com/thr...a-0-93a.62713/
        • shlomim412
          • May 2018
          • 45
          • israel
          hi
          checked with IPA over u3000, doesn't seem to get warm or evaporates the IPA faster than surrounding chip \ caps...
          ssd voltages seem to be ok
          getting
          2.5v on PP2V5_NAND_SSD0
          1.79v on P1V8_LX0_SSD0
          0.89v on PP0V9_SSD0
          i don't have thermal camera, but from what i can tell
          the ssd chips are getting a little bit warm, and ofcourse cpu and gpu is cold (no vcore)..
          • mon2
            • 14657
            Voltage to ground of ppbus_g3h ?
            • shlomim412
              • May 2018
              • 45
              • israel
              it's 12.6 and than dropping to 12.28 than back to 12.6 and again 12.28\9
              it's cycling like this on ppbus_g3h...
              • mon2
                • 14657
                Remove fuses F7000 and F7001.
                Then measure the voltage to ground of PPVBAT_G3H_CHGR_REG at F7000, pin #1 (ISL = producer side of this rail).
                What is the measurement without the downstream consumer load?
                • shlomim412
                  • May 2018
                  • 45
                  • israel
                  with f7000 and f7001 removed i measured 12.27-12.28v on pin #1 of f7000..
                  • mon2
                    • 14657
                    Remove all power. Measure the resistance to ground of F7000, pin #2 (consumer side).
                    What is the measurement?
                    • shlomim412
                      • May 2018
                      • 45
                      • israel
                      it's showing 0.0 at the beginning and than 1.2 K ohm and climbing up to 4K + and keeps climbing...
                      measured with red probe to ground.. (this the correct way to go?)
                      either way all power removed...
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        PPBUS_G3H is fine.
                        Damage on 2.5V SSD regulator very often means dead SSD ICs. Measure resistance to ground on both rails SSD0/SSD1.
                        • shlomim412
                          • May 2018
                          • 45
                          • israel
                          only have ssd0 on this specific board...
                          PP2V5_NAND_SSD0 is 30 ohm to ground :|
                          much lower than good working board..
                          rest seem to be ok...
                          is it worth to inject voltage? or simply dead ssd?
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            You'll probably see SSD ICs slowly warming up on thermal camera. They need to be replaced, after making 100% sure all power circuitry is good (so that it doesn't kill replacement SSD ICs).
                            • shlomim412
                              • May 2018
                              • 45
                              • israel
                              in cases of a short like this, all ssd chip are damaged?
                              how do you advise to make sure all is good, before installing new ssd ic's?
                              the short should be gone after the bad ssd ic's are removed?
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                All of them may be damaged, but you could always inject voltage and remove ICs getting hot under thermal camera one by one.
                                After removing the bad SSD ICs, resistance to ground should come back to a few kiloohms on the 2.5V rail.
                                Make sure there's no corrosion left around and under the buck controller, and make sure all the voltages are good and stable before putting replacement SSD ICs in.
                                • shlomim412
                                  • May 2018
                                  • 45
                                  • israel
                                  thank you very much for the help
                                  if ssd ic's comes from donor board of same model
                                  what should i look for? solder each one back to the same place?
                                  in case like this they need to be programed?
                                  • fajfelek
                                    Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                                    by fajfelek
                                    Hello, First of all thanks you for reading this topic.
                                    I need your help with identify missing parts on trackpad logic board (661-18430).
                                    The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                                    Please help me with identity parts from blue and red area .
                                    06-15-2024, 01:41 PM
                                  • BMCappelletti
                                    Macbook Air A1466 EMC 3178 missing power and liquid damaged
                                    by BMCappelletti
                                    Hi everyone.
                                    Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
                                    Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
                                    04-15-2024, 01:24 PM
                                  • geiti94
                                    Macbook Pro A1990 PP5V_G3S missing
                                    by geiti94
                                    Hello to all
                                    I have a macbook pro A1990 820-01814 that dont turn on
                                    PP5V_G3S and PP2V5_NAND_SSD0 are at 0V instead of 5V and 2.5V
                                    Someone have a sugestion where t start for find the problem?
                                    i cant set the unit in dfu mode
                                    12-15-2024, 10:59 PM
                                  • Nikan.e
                                    MacBook A1989 missing rails PP3V3_S5 and PP1V8_S5
                                    by Nikan.e
                                    Greetings and Salutations,
                                    I have gotten an A1989 Macbook board number 820-00850-A which has two missing rails -> PP3V3_S5 and PP1V8_S5.
                                    PBUS is at 12.6V every other voltage made by the PMIC is just fine.
                                    Resistance to ground -> PP3V3_S5 ~ 220Ω
                                    Resistance to ground -> PP1V8_S5 ~ 220Ω
                                    PP1V8_S5 and PP3V3_S5 are not shorted together.
                                    Voltages up to PP2V5_NAND_SSD0 seem to be fine.
                                    Can anyone confirm if these resistances are normal for this board?
                                    What could be causing this issue?
                                    Is there a way to...
                                    12-04-2023, 03:44 AM
                                  • Instafixx
                                    Macbook A2179 820-01958
                                    by Instafixx
                                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                    I checked the Power Sequences below and found this -
                                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                    05-20-2023, 05:19 AM
