Alienware 17 R3 power on and shuts itself off and stays off
  • mon2
    • 13862
    Re: Alienware 17 R3 power on and shuts itself off and stays off
    I think the secret lies inside the aptio screen.
    What does the load defaults do for you?
    Insert a usb thumb drive. Do you see any activity? Some websites claim the bios can be reflashed using this method and screen.
    • waakye
      • Dec 2018
      • 340
      • Electronada
      #62
      I am able to flash the bios in the aptio screen using a USB drive but the machine turns off when it get to 90% at the EC FIRMWARE UPDATE. I will upload a video soon. Maybe that would help alot.
      Thanks again
      • mon2
        • 13862
        Review the EC area. Is there a flash IC nearby? What are the topside markings of the flash chip? Confirm it is soldered properly.
        Was this chip removed?
        Confirm the power rails of the EC.
        • waakye
          • Dec 2018
          • 340
          • Electronada
          #64
          The video is too big to be attached. Honestly I don't know what the EC chip is . There are 4 Bio looking chip. UH4, UE2, UT2 and UT5.
          I will look in the schematic if I can locate the EC chip.
          Thanks again.
          • mon2
            • 13862
            EC chip will be a TQFP package and large in size. Perhaps 160 pins with same number of pins on each side. Perhaps ITE or EN markings.
            If the flash is external, small 8 pin soic are common and from Winbond. Will be similar to the main flash device but a lower density as it runs smaller firmware.
            • waakye
              • Dec 2018
              • 340
              • Electronada
              #66
              Ok thanks for the lead. i will review the EC area and report back.
              Thanks again.
              • waakye
                • Dec 2018
                • 340
                • Electronada
                #67
                I posted a video on YouTube about the issue am experiencing since the file is too big to post it here.
                The link is below hopefully someone can help me out since am out of ideas.
                The machine turns on and off within 6 seconds. I disconnected the AC plug, plug in the USB drive with the Bios to flash 1.8.0 and press the ESC + CTRL key and plug in the AC plug and press the power button. Once the screen turns on I released the ESC + CTRL keys and the recovery screen is displayed.
                I select the recover Bios and the following in the video below happens:
                https://youtube.com/shorts/e1l0gut9DJs?
                The machine turns off during the EC FIRMWARE UPDATE and then tries to turn on but turn off immediately.
                Thanks for all help.
                • waakye
                  • Dec 2018
                  • 340
                  • Electronada
                  #68
                  Does anyone has any insight in why the system is behaving like that. Is this a graphic card issue?
                  • waakye
                    • Dec 2018
                    • 340
                    • Electronada
                    #69
                    Any help guys?
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      #70
                      Will someone help me out with this. I am stuck. I tried flashing many firmware and the machine still turns on and off in 6 seconds.
                      • waakye
                        • Dec 2018
                        • 340
                        • Electronada
                        #71
                        Do you guys think the the CPU is shut?
                        • waakye
                          • Dec 2018
                          • 340
                          • Electronada
                          #72
                          I ended up stripping the machine for parts.
                          Thanks all that helped.
                          @Mon2, @Sephir0th thank you guys for helping. I learned alot from you.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            03-31-2024, 02:12 PM
                          • Green Probe
                            Alienware m15 R5 Ryzen No Power
                            by Green Probe
                            Hello, I have an Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0, Ryzen 9 5900HX, RTX 3070. I got it due to it having liquid damage. I am quite new to chip-level repair, and this is my second post, so please be kind with my incompetence. The charging IC is an ISL95522ah in HPB mode as far as I'm aware. I've been using a schematic for a LA-K455PR10_0525A that is available in the forum, and it seems to match for the most part. If it's okay I can link the schematic, or insert the pertinent page into my post.
                            It had some crusty areas that I've cleaned up....
                            02-05-2024, 02:46 PM
