Dell Inspiration 13 - can not enter BIOS
  • Jane
    • Aug 2010
    • 189
    When I press F2, to enter BIOS, the laptop turns off.
    Where can be a problem?
    BIOS chip?
    Thank you for a hint.
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
  • mrrubik
    Dell Optiplex 7010 micro bad BIOS flash?
    by mrrubik
    Hi folks,
    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
    Steps I took:
    1. Read BIOS with CH341a, verified hash twice
    2. Patched
    12-23-2024, 04:11 PM
