Asus Rog Laptop new battery still 0% Biard issue?
  • irepair559
    • Dec 2022
    • 134
    Re: Asus Rog Laptop new battery still 0% Biard issue?
    ok guys i finally got the g4 gud mosfets i installed it now i get lights.. Hard drive spins.. The otger ssd drive gets little warm.. I get 20v in most areas and 12v and 5v and 1v .. but doesnt want to boot up? Is it normal for these gaming laptops to power up the hard drive without pressing the power bitton?
    heres a video , thanks guys.
    https://youtu.be/puVxp_M50vw
    • Stevedb
      Stevedb
      • Feb 2018
      • 623
      • Belgium
      #82
      Did you already give all resistance to ground on every coil and also try an extern keyboard on to see if capslock is responding? If not responding will say the board is not posting i would look into for bios issue.
      • irepair559
        • Dec 2022
        • 134
        so what should the coils normally measure in ohms?
        Yeah its wierd ssd gets warm and the 2.5 inch drive spins.. but doesnt want to boot.. maybe the bios did take a crap?
        But i did notice after replacing the mosfets one of them gets no voltage at all ? i checked all the other similar mosfets and they get some sort of voltage from 1v-20v ..
        maybe power is not passing through that line ?
        The original mosfets were "G4 GUD "
        THE closest i found were "G4 GUC " ?
        • irepair559
          • Dec 2022
          • 134
          coils ohm measurements are all diff, some are 1ohm near the cpu/gpu some are in the Kohm some are OL ? im just afraid if by changing the mosfets since there so close to the cpu /gpu if i fried them. How can i test the bios chip ?
          • Stevedb
            Stevedb
            • Feb 2018
            • 623
            • Belgium
            #85
            You need to give all resistance to ground over all board wothout any power and give also the voltage you have on the coils too that with power. so that somebody can help you where the problem is. Put it on hd picture. I said to see the board connect usb keyboard and see if capslock respond. If it does then will it say the board is posting and bios is working. Good luck
            Regards
            • irepair559
              • Dec 2022
              • 134
              All coils have voltages but the ones near the cpu have nothing.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #87
                Clear the mess in the circled area(black) and post a clear pic of the highlighted area. measure resistance to gnd on Vcore /VCCSA/VCCGT coils in ohms mode. No power should be attached while measuring resistance.
                • irepair559
                  • Dec 2022
                  • 134
                  the ls a resistor on the left just bad soldering lol , the burnt cap area is cleaned no short thats just uv mask.
                  Which coils should i check ? sorry dont know what lines those are. I should get voltage on every mosfet right? but the G4 GUC mosfet one right under the burnt cap is getting no voltage on either side. maybe wring replacement mosfets? Original ones were G4 GUD , i only found G4 GUC ?
                  • irepair559
                    • Dec 2022
                    • 134
                    Here are the coil ohm readings
                    Sorry for my bad drawing lol
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 623
                      • Belgium
                      #90
                      So what is the issue right now is the board working and not the battery?
                      • irepair559
                        • Dec 2022
                        • 134
                        No it doesnt boot.. Lights come on, hard drive spins and ssd gets warm. But wont boot. But why would those kick on withoit pressing the power bitton?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #92
                          "coz the mb is turning on. This happens when you remove cmos cell/flash bios/backup battery not attached/removed. So thats not the issue. Vcore will rise after all its requirements are met(as long as its not shorted).
                          Check whether you have +VCC_SA/1.05V rails running. The resistance on CPU seems bit low to me-Have seen 2-3 ohms atleast but may be correct as its a gaming board.
                          • Stevedb
                            Stevedb
                            • Feb 2018
                            • 623
                            • Belgium
                            #93
                            Can you toggle numlock or capslock on external keyboard?
                            • irepair559
                              • Dec 2022
                              • 134
                              the cmos is around 2v and i tried with battery connected and dissconected same thing..
                              I do get 1v on a mosfet near CPU / GPU.. I see 1v, 3v , 5v , 12v 20v all over the board..
                              But where is +VCC_SA/1.05V ?
                              Just that one mosfet i pictured near the burnt cap area not getting any voltage on S G or D ..
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #95
                                VCCSA coil will be near to cpu. Normally 4 coils are there for vcore,one for vccgt and another one for vccsa. 1.05 rail coil should be near PCH. Post a clear photo of the area near cpu so that we can try to identify vccsa coil.
                                • irepair559
                                  • Dec 2022
                                  • 134
                                  Ok only 1 coil has 1v rest no voltage..
                                  I came across something interesting when measuring voltages on those little mosfets , they ones i pictured getting no voltage on any side. If i place my finger on it while measuring source i get voltage of 4-5v then dropping? ( its not loose solder joints i redid 3 times ) I think the gates on these mosfets need 5v to turn on? I do notice a restitor or something near those mosfets that has 4-5v maybe that line is cut? Is that possibly the line that feeds those mosfets gate?
                                  • irepair559
                                    • Dec 2022
                                    • 134
                                    i think i found the issue , maybe missing component here ?? These points have continuity to the gate? The other similar mosefts all have a component that connect to the gate.
                                    Its on the corner of the board near the gpu Asus GM501GS maybe a scematic will verify ?
                                    • irepair559
                                      • Dec 2022
                                      • 134
                                      what do you think ??
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        #99
                                        Cant say anything in absence of schematic but very likely its not populated from factory.
                                        • irepair559
                                          • Dec 2022
                                          • 134
                                          ok got back to where it was last week.. was bad mosfet
                                          Now still stuck on lights on.. sata spins...ssd gers warm.. but cpu and gpu cold ( off ? )
                                          Can this be bios issue?, so close guys..
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
                                          • huzo
                                            HP ELITE X2 1013 G3 weird battery issue
                                            by huzo
                                            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                            01-31-2025, 12:09 AM
                                          • danielsak
                                            Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                            by danielsak
                                            Hello, I have issue with Dell Inspiron 3542.
                                            Motherboard marking:
                                            Code:
                                            PWB FX3MC REV: A00
                                            The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                            1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                            1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                            10-11-2024, 04:36 PM
                                          • rob777
                                            Asus TUF won’t run off battery
                                            by rob777
                                            I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                            I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                            Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                            Thanks....
                                            05-27-2025, 07:07 PM
