Could HP middle pin cause damage to SOC?
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. I am about to get my new motherboard for a damaged starwars edition HP laptop (15 an001). The original motherboad got a short on 3.5v line, I traced it to the SOC (processor) and with the price of a new reballed i5 processor, it was better to just buy another board.
    I still don't know why it would fail all of a sudden, I had just paced it down, I was watching a video, it kept playing then a second after I placed it down it shut off.
    Now I am wondering if I should buy a new power supply, maybe there is a short between the middle pin and 19v line that occured when I moved it. I haven't measured anything off, but the question arises, could high voltage on the middle pin cause damage? I am guessing not, looking at the schematic, there is a zener diode on the line, which should protect the system, plus it seem to go to the kbc (EC) chip, not the SOC. But can anyone confirm my thoughts?
    Can a high voltage (19v) on the middle pin cause damage?
    Here is a snip of the scehamatic for the adapter detect section:
  • reformatt
    • Feb 2020
    • 1495
    Re: Could HP middle pin cause damage to SOC?
    If the DC socket collapses and shorts 19V to the sense pin, the protection is there to prevent damage further down the chain. It goes to the EC though, not the PCH. Only ones I've heard of damage in this respect are some Lenovo's lappies. Most manufacturers have some level of protection on the adaptor sense pin when the socket disintegrates.
    PCH failures are usually from a variety of things. Overvoltage on either the +3.3V or +1.05V rails is one. But given the PCH connects to the outside world via USB etc, it's more likely to come from there than the external adaptor. Sometimes they just fail too.
    • reformatt
      • Feb 2020
      • 1495
      Forgot the most common one...liquid damage!
      • liquidzorch
        • Oct 2016
        • 135
        • mexico
        Thank you! That's what I thought, just wanted to verify before going out to buy another adapter.
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
        • otaku_nut
          Vizio E701i-A3 fixed but now has red vertical line
          by otaku_nut
          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
          08-19-2025, 06:11 PM
        • TrueSword88
          Kogan - KALED65XU9220STB - Blue Vertical Line
          by TrueSword88
          Hi all.
          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
          The line just happens to coincide with the end of COF and start of the next COF (attached).
          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
          Hoping to fix...
          05-05-2023, 04:28 PM
        • FALKLAN
          Running Line Voltage and Integrating LED Pods - Automotive
          by FALKLAN
          Howdy everyone! I hope all is well where ever you are!
          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
          02-05-2025, 12:30 AM
        • dbuergi
          Macbook A2442 no display board 820-02098
          by dbuergi
          i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
          So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
          05-25-2025, 10:58 AM
